pressure in the gas tank WAY high
alright i open my gas tank and **** load of pressure is coming out. i cut one of lines that went to charcoal canister and punch it. since i didnt need anymore. im gonna say thats why.
any in thoughts. should i just open the line in between the gas tank and the car and leave it open?
same thing has been occuring with me... today gas was leaking out of the cap so I take the cap off and as soon as I do that gas comes flushing out... this has never happen to me before the past month or so... Im thinkin maybe I have something squished or blocked cause I did my swap a couple months ago! and it never happen to me before that!!!!! well theives are tryin to get me so it looks like a good time to have the car down and figure out the problem!
This is very likely due to a failure in the purge cut solenoid area under the hood. Let me explain:
There is a mysterious charcoal canister on the firewall with a hose coming out of the firewall into it. The canister is there to contain the gasses that emerge from your gas tank when it expands due to sitting and the ambient temps getting warmer.
When you turn on the car, The ECU sends an electrical signal to the purge-cut-solenoid on your firewall (or manifold if you have a later manifold). The signal opens the solenoid for a couple of seconds, and that allows the vacuum channel to your intake manifold to pass through the purge-cut solenoid to the top of the canister.
That vacuum then opens the mechanical valve on the canister and allows the captured fumes inside it to be sucked into the intake manifold, via the braided red hose, to be burnt.
The whole point of this overly complex system is to prevent those gasses from being released into the environment, but without the danger of an electical switch right there on the canister.
I hope that helps.
You can either test/replace the solenoid (the right thing to do for californians and environmentalists), or put a filter in place of the canister.
I hope that helps.
I hope that helps.
I hope that helps.
worked to perfection!!!!
mariner133
Aug 8, 2018 01:01 PM
GI8U2racing
17
Mar 26, 2007 01:27 PM
but its like **** load of pressure lol
