99 civic with gsr swap power steering
Old Apr 18, 2009 | 12:37 PM
blackccoupe's Avatar
Default 99 civic with gsr swap power steering
i got a 99 gsr swap in my 99 civic what do i have to do or use to put power steering as far mounting the pump itself, the brackets are different for the pump
Old Apr 18, 2009 | 12:49 PM
infinitypro12's Avatar
Default Re: 99 civic with gsr swap power steering
Pretty sure you need a b-series bracket. Kudos for keeping your power steering, seems rare these days. I have the same swap but it came out of a friends civic so it was all ready to go. Hopefully someone else will approved or deny my claim.
Old Apr 18, 2009 | 06:41 PM
the gsr backets are different and dont work
Old Apr 18, 2009 | 07:23 PM
will the 99 crv steering bracket work on gsr engine
Old Apr 18, 2009 | 09:10 PM
geebs's Avatar
Lower b series p/s pump bracket.. p72 bracket for the head.. and a 99-00 si pump, or ctr pump..
Old Apr 18, 2009 | 09:13 PM
k i got the brackets but how will i know if the pump will work with my hoses
Old Apr 18, 2009 | 09:23 PM
geebs's Avatar
What pump do you have? only the 99-00 si, and ctr pump will work. Link shows the difference. When I did my ls/vtec in my ek sedan, I used a ctr pump.. Found it for like $30 on ebay, works fine.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faq-retaining-power-steering-ek-b-series-swap-1822781/
Old Apr 20, 2009 | 02:46 PM
where can i get those pumps i cant find any?
Old Apr 20, 2009 | 03:02 PM
robfrmny21's Avatar
get one for 99-00 si, also gsr ps is bigger then si one
Old Apr 20, 2009 | 07:40 PM
i read that a 98-01 integra pump will work also
Old Apr 23, 2009 | 05:57 PM
Old Apr 24, 2009 | 04:17 PM
ok 98-01 integra pumps work incase anyone wanted to know
Old Apr 24, 2009 | 05:49 PM
j_vision's Avatar
troof sir. i have this on my hatch as well.
Old Apr 24, 2009 | 07:14 PM
Vindicator9000's Avatar
318 Curves, 11 miles
I'm about 99% certain I'm running an 01 Integra pump on mine with the original gsr bracket. It came bolted to my gsr motor that came straight out of a wrecked 01 gsr.
Can't vouch for all years of engines/cars, but it works on my 00 civ.
OP: did a PS pump not come with your engine at all? Do you have a bracket at all? If you have the gsr bracket, I'd say get the teg compressor. If you have no bracket, I'd say pickup whatever you can get cheaper - teg or 99-00 Si.
Old Mar 17, 2020 | 10:32 AM
Nicholasm139's Avatar
OP: did a PS pump not come with your engine at all? Do you have a bracket at all? If youve the gsr bracket, I'd say get the teg compressor. If you have no bracket, I'd say pickup whatever you can get cheaper - teg or 99-00 Si.
Hey man I know I’m 11 years late but I want to have power steering in my GSR swap in my 2000 civic. Did the hoses line right up to the GSR pump ?
Old Nov 14, 2020 | 07:07 AM
Jdpt2's Avatar
5 Year Member
Interested to know as well.
Old Nov 14, 2020 | 08:19 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
It depends on what year GSR swap you have purchased. Try it.
ohsnapzafingcu
Dec 8, 2008 07:22 AM
TYPERman2001
May 16, 2008 10:05 PM
93civiconair
Apr 16, 2005 09:02 PM
