Help
okay i have a 1990 crx dx 1.5 L you know just stock. I'm havin trouble gettin this thing to run rite.my rpms gauge jumps around and it wont rev pass 2.5 grand. starts cuttin out and feels like has no power. looked at my e.c.u and i have a 20 count code goin on. So need some help on figurin out why its doin this so any help would be great cuz i'm stumped
The code 20 indicates there is a problem in the Electric Load Detector Circuit. What this circuit does is monitor the loads placed on the engine by the alternator, A/C and headlights, among others. When an additional load is detected, the PCM raises the idle speed to compensate. The PCM has detected a fault in the system and turned the light on.
Here's how to test the system:
1. Remove cover from main fuse panel located in engine compartment, then disconnect electrical connector from electric load detector unit.
2. With ignition switch On, check for battery voltage between electrical connector positive (black/yellow wire) terminal and negative (black) terminal.
3. If battery voltage is present, proceed to step 4. If no voltage is present, check for the following:
* Check for blown No. 14 fuse in instrument panel fuse box.
* Check for open circuit in black/yellow wire between instrument panel fuse box and main fuse panel in engine compartment.
* Check for improper ground (black wire) connection.
4. With ignition switch On, check voltage between electric load detector electrical connector green/red terminal and ground. Voltage should be approximately 4.5 to 5 volts. If voltage is as specified, proceed to step 5. If voltage is not as specified, check green/red wire between electric load detector and PFI electronic control unit. If wiring is satisfactory, electronic control unit may be at fault.
5. Connect electrical connector to electric load detector unit.
6. With ignition switch in On position and headlamps on at low beam, check voltage at green/red wire terminal at electric load detector unit electrical connector. Check voltage with connector still installed on unit. Voltage should be approximately 2 volts. If voltage is as specified, electric load detector unit is satisfactory. If voltage is not as specified, engine compartment main fuse panel and electric load detector unit must be replaced as an assembly.
RotaryTraitor89
Jul 15, 2007 01:41 PM
BKGuy
Jan 8, 2007 12:22 PM
