Need Help been working/ searching for info sense b4 sept so plz look and help me
I posted this in the tech/misc so if an admin wants to lock or remove plz feel free to
OK well here is pretty much the details 00 si pretty stock exhaust and intake. This all started like i said b4 sept. last year so its been going on to long and i just need help idk wtf to do any more with it lol.
Probs (in order as they occured)
1. speedo stopped working at total random
2. all dash lights when off i turned car back on everything was fine
3. while driving the rpm guage stopps working
4. car begins the idle rough as ****
5. it dies and dosent even have enough power left to get even the annoying key in ignition sound
6. Took the car to a freind of the family that is all a mech. and found that the 7.5 amp fuse for the radio was creating a draw. So i remeoved it, after that the battery only goes down if i drive it
7. Took the car to honda to have a diagnostics done or w/e, the engine codes and probs they saw were this,
code p1298 aka circuit high voltage
code p0500 vehicle speed
code p0325 knock sensor
code p0141 o2 sensor 1 and 2
PCM will loose connection at times
wires cut and retaped at ecm ( was a vafc controller i know all my wiring is correct)
knock sensor missing (it wasnt so idk wtf they are one)
They also told me that b/c my pcm was loosing connection at times it was causing the alt not to kick on and off.
What i have done to try to fix it.
Bought new speedo put it in and also tested old one both were good no effect at all
Bought new ecu no effect at all
Put in a good guage cluster no effect at all
Took off engine harness and checked for bad wires ect.
Took off alt. had it tested it was good
Took out bat had it tested it is good
Put in a new knock sensor
So after doing all that its still the same old **** another day and idk wtf to do anymore should i get a new engine harness and put it on b/c i have eliminated the ecu speed sensor and cluster so it must be wiring. Or should i be searching for some random dash wire that is messed up? btw i have searched the engine bay and took most of the dash stuff apart looking for any loose connections grounds ect.
mostwanted_ek
04-25-2018 03:58 AM
BKGuy
01-09-2007 08:43 PM
DC2 Mang
05-09-2005 08:55 AM
rustycivic
09-21-2002 05:58 AM
