Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Spring Question...Among Others
Old Apr 18, 2009 | 08:45 AM
JayJie15's Avatar
Default Spring Question...Among Others
Hello, looking to start modding the batmobile and am new to this so a lot of questions have arose. I have read most of the threads on here about what kind of springs people suggest running and am pretty much set on the Eibach Sportlines. My question is regarding to if I continue to run my stock si shocks/struts how well and long will they hold up? Also, would I need to buy a camber kit with just springs? Also, if I did end up having to go aftermarket with the shocks/struts I was looking at KYB. Any other suggestions would be great. After this is said and done HFP 18" wheels, HFP lip, and Magnaflow cat back. Then the waiting process begins for it to be payed off so I can go with forced induction. I appreciate all of the good posts on here and have really enjoyed being a member of this community thus far.
Old Apr 18, 2009 | 09:03 AM
teggsr925's Avatar
Default Re: Spring Question...Among Others
you will be fine running on stock struts, for probably 40,50k. i ran springs on my teg on stock struts, they had over 120k miles on them, and about 20k with springs and no problems.
the ride might be a little a bouncey tho. camber kit shouldnt be neccesarry. as long as u get an alignment after the springs settle to correct toe, and rotate tires every few thousand miles.
Old Apr 18, 2009 | 09:30 AM
FijiBlueFG2's Avatar
Road House
I can say that at about 9000miles, my stock suspension is starting to slightly loosen up. Very slightly though.
Old Apr 18, 2009 | 09:48 AM
teggsr925's Avatar
wat do you mean loosen up? like your struts going bad?
i have 17k on my car with springs and no problems
Old Apr 18, 2009 | 11:06 AM
vladd's Avatar
i think that on most cars the struts go bad so gradually that you don't notice it until they're really bad, meaning that you won't notice your struts going bad until they're completely done for.
as for the op, a camber kit is a good idea if you want to improve your handling, it's not necessary for tire wear though.
Old Apr 18, 2009 | 11:11 AM
Zeusone's Avatar
ive had springs on my sock struts for about 35k with no problems. camber kit is necessary due to the added camber that occurs when lowering the car
deviant1
Jun 30, 2007 02:14 PM
Kill_Phil
Suspension & Brakes
Jun 6, 2005 04:08 PM
darkvibe
Aug 30, 2003 07:44 AM
jeddy0120
10
Mar 13, 2003 04:22 PM
Type Goch
May 2, 2002 10:54 AM
