Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Why is my car stalling?
Old Apr 18, 2009 | 07:13 AM
K.dot's Avatar
Default Why is my car stalling?
Well Lastnight I was driving my car on the highway but for some reason it wouldn't let me go over 70mph. Every time I increase my speed on the highway my car starts to stall and shake. The Check Engine Light comes on(it goes away after I slow down). What causes this problem ? FYI I have a 2001 civic LX.
Note. I took it to honda and they said I needed my spark plugs changed. I changed it and it still stalls when I speed up on the highway.
Old Apr 18, 2009 | 07:33 AM
pgpunkguy's Avatar
Default Re: Why is my car stalling?
sounds like either fuel or ignition... maybe your timing is off from a loose distributor bolt? check your distributor cap/rotor/coil... check your fuses too...
Old Apr 18, 2009 | 07:59 AM
It Wasn't Me's Avatar
That's good advice, man! Now, be a pal and show him (and us) where those items are located on a D17.
Old Apr 18, 2009 | 08:06 AM
PSI GUY's Avatar
I have had bad TDC sensors that produce the same symptoms, the sensor thats bolted to the head that reads off the cam gear. All the cars i replaced them on had the same characteristics......
Start okay, once warm won't rev up, won't do much more than 50 and will stall and hard to restart. But will usually give a code for the sensor.
Old Apr 24, 2009 | 06:49 PM
civic=goodgasmileage's Avatar
pretty much it's your crank shaft position sensor (CKP sensor) it's by your timing belt. i'm pretty sure it's that. my car did that too. cel came on. checked it and it was my ckp sensor. maybe your belt might be rubbing against your cover that's why it might be your ckp sensor.
Old Apr 24, 2009 | 07:59 PM
dtapia's Avatar
Good call
i don't see the distributor bolt still LMAO.
Old Apr 24, 2009 | 11:29 PM
langjairicer's Avatar
This might be a stupid answer but; did you check the oil? I have a feeling >=]
Old Apr 25, 2009 | 07:02 AM
GriFFIthS's Avatar
I'm pretty sure the D17 doesn't have a distributor.
Old Apr 25, 2009 | 09:55 AM
dopejdmes1's Avatar
would it be because it went into 'limp mode' or whatever...? just an idea, maybe someone else can add onto this
Old Apr 25, 2009 | 11:02 AM
jdmfreak1992's Avatar
First off pull the codes before you just start poring money into parts you don't need.
Old Apr 25, 2009 | 11:31 AM
stevenDAtegra's Avatar
correct
Old Apr 26, 2009 | 10:31 AM
UrPully's Avatar
I should recommend finding a guy that works on Honda's or Nissan
Just bring a 6 pack of beer find a guy that has the smarts to troubleshoot
and you'll have yourself a happy civic
Old Apr 26, 2009 | 08:17 PM
Gt limited(jdm approved)'s Avatar
when we use e10 87 in our honda stream....civic based d17a vtec
after a while is stalls esp when hard driving
preludepower01
Sep 3, 2007 08:07 AM
erik92DA
Jun 8, 2006 08:16 PM
bobdlee
Oct 23, 2005 05:09 PM
BoostedH23a1
Apr 18, 2005 03:19 PM
mR. Vash
Sep 8, 2004 10:50 AM
