Going from 103 to 110 octane
Old Apr 17, 2009 | 08:14 PM
MARVNVRAM's Avatar
Icon2 Going from 103 to 110 octane
Because of availability issues I'm thinking of running Sunoco 110 leaded, instead of my current VP 103 unleaded. My question is how will this effect the current tune I have on 103? Will I need, or would you recommend, to go back and retune? Thanks
Old Apr 18, 2009 | 05:40 AM
patriot's Avatar
Default Re: Going from 103 to 110 octane
Would you retune if you went from 87 to 93?
Old Apr 18, 2009 | 10:20 AM
00Red_SiR's Avatar
All Motor Mentor
Running leaded gas is gonna kill your O2/wideband.
Old Apr 18, 2009 | 12:39 PM
MARVNVRAM's Avatar
I realize it'll kill the O2 but i don't run one, only have one I use to tune then plug the O2 bung when I'm done. Just wanted to know if the change in leaded/unleaded octane will be drastic. I know a couple guys have their engines tuned on 93, but once in a while will run 110. I'm not a tuner so just wanted the info before I make the change. My tuner says we might need an adjustment but on his personal engine he can go back and forth between 93/110 no problems.
Old Apr 18, 2009 | 01:53 PM
00Red_SiR's Avatar
All Motor Mentor
From what I know, you can go back and forth but if your engine isn't tuned to take advantage of the extra octane (usually a more aggressive timing map), it makes no sense to use more than 93 octane if it was tuned for 93.
Old Apr 18, 2009 | 02:58 PM
patriot's Avatar
Exactly. You may even lose power and fuel economy using a higher octane fuel...assuming you are actually tuned for 93.
Old Apr 19, 2009 | 09:46 PM
C_Rock77's Avatar
Never actually heard that before....
But...you'd DEFINITELY be wasting money by running Pump premium in a car that doesn't need it.
Will the fact that the gas is LEADED have anything to do w/ anything BESIDES killing the Wideband?
See Are X
Sep 14, 2006 05:25 PM
DeadVet
May 21, 2005 02:02 AM
patdemps
May 11, 2004 07:57 PM
eh-D
Feb 6, 2002 05:25 PM
S13Koop
Nov 23, 2001 11:16 AM
