Need help b20b
I just swapped a b20b into my friends 95 honda civic ex the motor starts up nice but after a few seconds the idle just drops really low and the car dies out. The motor is a stock b20b with a ls tranny, we are using an ls intake manifold and ls ecu, we are also using his stock ex engine harness. I cant figure out the problem so any help would be great
I am having the same exact problem. I believe its the vacuum routing but I am not sure how to get it right. If anyone has any input on this I would greatly appreciate it.
check the little black purge valve on the back of the manifold, if thats hooked up backwards with the idle air control it will shut the car off, had the same problem, and just for the record a B20B with a LS ecu will make the motor run slightly lean. a FPR or a Vtec/AFC and +20 it and it will fatten it up a bit
your right about the ls ecu but on the car it warms up and once its warmed up it idles low and then dies out and if it doesnt die out it just stays idle and then it just drops suddenly then it jumps back up and drops again the idle basically bounces alot and it smells really rich in fuel too
