Can I use the jdm afc for the hack....is +/- 30% enough?
I'm putting together a budget turbo. And I'm only going to be boosting between 6-8psi on stock internals.
I'm wondering if the jdm s-afc with dials that adjust fuel +/- 30% at 800, 2400, 4000, 5600, and 7200 rpm's would be enough with smaller injectors to manage my fuel for that psi level?
Is anyone using this to implement the afc hack? Or can someone give me insight on how I might be able to get this to work. Such as, what size injectors, will I need a fuel pump...etc...etc...
I tried searching, just didn't type in 30% I guess. Thanks though...
Sounds like it's possible, but I'm still wondering. So idle will be fine, and running rich will also be fine...not for the best performance, but it is safer than running too lean. So what size injectors would give me enough fuel for no more than 8 psi?
Also, would the jdm afc work with a '99 integra? I know you have to set the unit for your car...but it sounds like they were intended for late 80's early 90's vehicles.
Still looking for a deffinate answer....thanks.
[Modified by asianspeed, 4:04 PM 8/15/2002]
Is anyone running smaller injectors and smaller boost with the afc hack and does go under -30%?
buckfittyone
Feb 6, 2003 09:31 AM
