Plastic Adhesion Promoter?
Old Apr 17, 2009 | 07:34 PM
PinoyDelS0l's Avatar
Default Plastic Adhesion Promoter?
Can someone please explain whats the purpose for this? I just finished painting my poly urethane lip, and the guy at the automotive paint store said to use that stuff? But I didnt really understand what the purpose of it was for? I thought it was just Primer, Paint, then clear coat? But the sales associate told me to do, Plastic Adhesion first, then Primer, then Paint, Then clearcoat.. Need a good understand on this stuff. Thanks!
Old Apr 17, 2009 | 09:20 PM
DynastyRacer22's Avatar
Default Re: Plastic Adhesion Promoter?
plastic adhesion makes it stick pretty good but if you didnt use it its ok as long as you primered it it helps from the paint chipping off
Old Apr 17, 2009 | 11:23 PM
VW-Convert's Avatar
you'll see what it does when your paint is no longer part of your lip after you bump something with it
really it seems to be a 50/50 shot...is it adhesion promoter? is it the painter? is it the paint? is it the plastic?
*****this is my opinion
Old Apr 18, 2009 | 03:06 AM
Disease's Avatar
It helps in the adheasion of the primer to the plastic. Makes a chemical bond between the primer and the surface of the plastic. Without it, youre primer would not stick well enough on it's own to the plastic. You would only have your mechanical bond.(scuffing of part)
6thgenftw
Paint and Body
12
Jun 23, 2012 06:53 AM
onekoop
Paint and Body
Jul 28, 2008 02:45 AM
matmcg
Paint and Body
18
Mar 23, 2008 09:28 AM
JDubya
May 13, 2004 09:18 AM
B20 Twin Cam DC2
Dec 26, 2003 03:22 PM
