Paint question!
Old Dec 16, 2003 | 08:08 PM
B20 Twin Cam DC2's Avatar
Default Paint question!
Hey guys, I bought the comptech (read)polyurethane ITR 94-97 lip and have a nice DIY paintjob that needs a touch up after 2 years. My question is this; I need to remove the paint and my cousin has aircraft paint remover(the **** he used for his valve cover) can I use this to strip the paint on the lip without destroying the polyurethane? please help!
Old Dec 16, 2003 | 08:49 PM
B16OnTop's Avatar
Default Re: Paint question! (B20 Twin Cam DC2)
why not just give it a light sand job then primer it and paint over that? im not sure if the paint stirpper will ruin the material but my guess would be yes seeing how its not a harder substance
Old Dec 16, 2003 | 08:58 PM
Innovative LS's Avatar
I wouldn't use that stuff it might messup the lip, or do a test spot and see. I would do as said before, sand it down with some 500 grit paper and prime with primer that has a flex addative in it and sand smooth, and paint.
Old Dec 16, 2003 | 09:12 PM
NomacGSR's Avatar
that stuff is very powerful just wet sand and prime
Old Dec 17, 2003 | 01:19 AM
1998_4dr_gsr's Avatar
as stated before, wet sand till clear coat is off...apply couple of coats of primer then spray your base coat then your clear.
*cheers*
Old Dec 26, 2003 | 11:23 AM
opi's Avatar
opi
Default Re: (NomacGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NomacGSR &raquo;</TD></TR><TR><TD CLASS="quote">that stuff is very powerful just wet sand and prime</TD></TR></TABLE>
yeah, i used that industrial stuff on my old wheels to "burn" off the clear coat...it actually melted the clear.
for your lip, you might want to just wet sand it, than prime.
Old Dec 26, 2003 | 03:22 PM
2000GSRT's Avatar
Default Re: (opi)
I was looking at a can of aircraft paint remover the other day and on the back it said do not use on plastics.
6thgenftw
Paint and Body
12
Jun 23, 2012 06:53 AM
PinoyDelS0l
Paint and Body
Apr 18, 2009 03:06 AM
ITR EG
Jul 12, 2006 03:38 PM
danteisme
Feb 14, 2006 03:16 PM
bboyprelude
Jun 2, 2003 02:54 PM
