Gas pedal problem =[
Ok I just put my type r Mani on my Gsr and I used the type r throttle bracket and cable and my gas pedal is super sensative it feels like there is no weight bhind it. If a fly landed on it it would move the pedal and rev the car can someone pls help? My idle also jumped from 1000rpms to 1500rpms on the dot when I press the gas it revs and goes back down to 1000rpms but then jumps back up to 1500 replaced the gaskets correctly but can't seem to figure this out pls help hondavtec =p
any pics , did you check the trottle return spring it may be worn out or just on wrong ,mine is light. but it still has tension ,also the cable can be adjusted to adjust the trottle.It may be to tight lossen it up ,just a thought
Nick M
14
Apr 22, 2006 08:26 AM
