spun bearing is crank still good??
Old Apr 17, 2009 | 02:20 PM
leroyb's Avatar
Default spun bearing is crank still good??
im rebuilding my ls i was going to put a gsr crank but changed my mind since im going turbo so i rather go with the stock crank well i have a buddy that has a ls crank but said that came off a motor that spun a bearing how do i check if its still good??
Old Apr 17, 2009 | 02:28 PM
90Rexx's Avatar
Default Re: spun bearing is crank still good??
obvious signs of scoring and heat marks then you need to mic it. verify its within spec in multiple locations and theres no variation in your measurements from one place to another. usually if you spin a bearing the crank needs to be machined or replaced though.
Old Apr 17, 2009 | 02:40 PM
Mashimaro's Avatar
^yup, measure it out. if you don't have the tools or know-how, take it to a machine shop and they can do it.
i think typically, you don't want to have gouged out more than 30thou, correct me if i'm wrong
Old Apr 17, 2009 | 02:48 PM
leroyb's Avatar
yea ill prob take it to the machine shop or m i better off just going to the junk yard?
Old Apr 17, 2009 | 03:12 PM
90Rexx's Avatar
junkyard is gonna charge you the same to buy a motor as a machine shop to fix urs if needed. just take it to a machine shop.
a 30 thousansd gouge is gigantic. maybe you ment 3 thousands? lol
Old Apr 17, 2009 | 03:36 PM
IhateworkingoncaRs's Avatar
Of topic but I thought the Ls block was cast differently to where their crank was not interchangable with the other B series, same with the B16a's.
Old Apr 17, 2009 | 09:42 PM
leroyb's Avatar
so i cant use a gsr even if i wanted too??
Old Apr 17, 2009 | 10:14 PM
newtron63h's Avatar
its a pretty safe bet that the journal needs to be polished at a minimum. its very possible that it will need to be ground down and polished. this is fine for a relatively low performance(street) vehicle. but if you intend hard use, id suggest finding another crank. if it is gouged too bad then the crank is scrap because they dont make oversize bearings beyond a certain point.
s032105k
Dec 28, 2010 06:17 PM
90 integra da
Sep 29, 2010 10:08 AM
takumi604
Mar 26, 2005 09:23 PM
VRD^don
Nov 2, 2004 02:28 PM
bboy_gangsta
Feb 15, 2003 03:42 PM
