Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Timing beit repalcement 2000 Odyssey LX DIY
Old Apr 17, 2009 | 02:06 PM
rkpatt's Avatar
Default Timing beit repalcement 2000 Odyssey LX DIY
I am about to take the TB on my 2000LX on as DIY project .
I am trying to find out more about whether or no to replace the hydraulic tensioner/adjuster in addition to everything else ( timing belt,. tensioner , idler, camshaft seals , water pump, acessory belts ) .
I found some info at www.odyclub.com - http://www.odyclub.com/forums/showth...threadid=42884 but really am not sure whether it is necessary to replace the hydraulic tensioner .
Do they go bad ? (I live in GA if climate matters ) - Thanks
Old Apr 19, 2009 | 05:45 PM
90sedan's Avatar
Default Re: Timing beit repalcement 2000 Odyssey LX DIY
They can go bad, and they will end up leaking. You won't know if you need to replace it till you have everything apart. If it isn't leaking, you're fine but you can still replace it for piece of mind.
whiteboy-dc4
Feb 3, 2010 11:52 AM
dcmystery21
Oct 25, 2008 10:44 PM
EM-One
Jun 7, 2007 09:34 AM
mike944
Jul 25, 2006 01:29 PM
LicenzedToThrill
Nov 14, 2005 03:39 PM
