Horrible compression test results with endyn rollerwaves!!
Old Aug 15, 2002 | 01:48 PM
powerfulperformance's Avatar
Default Horrible compression test results with endyn rollerwaves!!
My compression test came back 220 200 210 238, any suggestion what the problems could be... I am running Endyn rollerwaves 12:1 compression with toda C ......
Old Aug 15, 2002 | 01:51 PM
Black R's Avatar
25 Year Member
Default Re: Horrible compression test results with endyn rollerwaves!! (powerfulperformance)
.....did you do a leakdown test too?
Old Aug 15, 2002 | 02:16 PM
Hooch'n's Avatar
Default Re: Horrible compression test results with endyn rollerwaves!! (Black R)
Yeah, leakdown will let you know if your in real trouble!
[Modified by 8400-RPM, 3:17 PM 8/15/2002]
Old Aug 15, 2002 | 02:27 PM
Big Phat R's Avatar
What bore of piston did you use? Who honed the block?
Old Aug 15, 2002 | 02:34 PM
sgT's Avatar
sgT
Default Re: Horrible compression test results with endyn rollerwaves!! (Big Phat R)
who assembled it?
Old Aug 15, 2002 | 02:37 PM
Austin's Avatar
Did you have your cam gears adjusted +, or - ?
Old Aug 15, 2002 | 02:41 PM
integratom's Avatar
Don't sweat the numbers unless you really feel your losing power or something else seems wrong. The spec-C is a big cam even on the low cam. The duration and whatever your gear settings are can cause low numbers. Granted those are suppose to be pretty hi comp pistons but until a leak down is done or you suspect something worse dont worry to much yet. Be sure engine was at operating temp and was WOT with all the other plugs out, I know seems basic but just wanted to mention that. YOu can try that rislone ring seal additive that helps sometimes with engines in which the rings didn't seat to well. I think its something you add to the oil only once leave it in for ?? how long or how many miles then drain and refill with fresh oil. HTH Goodluck
Old Aug 15, 2002 | 02:43 PM
integratom's Avatar
Default Re: Horrible compression test results with endyn rollerwaves!! (integratom)
Don't like the imbalance to much thats the thing that really worries me.
Old Aug 15, 2002 | 02:47 PM
sgT's Avatar
sgT
those numbers are low. try a different tester first.
komat
14
Sep 8, 2009 05:16 PM
humboldt_skim
May 31, 2008 08:18 AM
Mugen_DC2R
Oct 4, 2006 09:36 AM
SioneSi
Jun 18, 2003 11:36 AM
