Again! Complete legit SR20 $2500 front clip *S13* and others.
Old Aug 15, 2002 | 01:40 PM
g's integ's Avatar
Default Again! Complete legit SR20 $2500 front clip *S13* and others.
SR20 $2300 front clip includes tranny, ecu, wiring harness, more!
$1800 just for the if you want the long block....
Displacement: 1998cc (2.0 liter) Cam type: DOHC 16
valve, chain driven cam sprockets
Compression: 8.5 : 1
Horsepower: 205hp at 6000rpm Torque: 203 ft/lbs at
4000rpm
Stock boost: 7 psi
Aluminum alloy block and head with steel alloy sleeves. Distributorless,
crank angle sensor activated ignition, direct fire coil packs. Stock SR's
come with an internal wastegate, a knock sensor, a side mounted intercooler
and a bypass valve that is routed back into the intake after the MAF before
the turbo. Stock turbo outlet is 1 7/8 inches, inlet and throttle body are
~2 1/2 inches.
Also have s15 clip for $5500
And JDM obd1 GS-R clip for $3500
(also legit and have papers for both....)
Old Aug 16, 2002 | 11:32 AM
g's integ's Avatar
Default Re: Again! Complete legit SR20 $2500 front clip *S13* and others. (g's hybrid)
bump
Old Aug 17, 2002 | 05:35 PM
g's integ's Avatar
ttt
Old Aug 17, 2002 | 08:16 PM
x916's Avatar
free bump for you man
Old Aug 17, 2002 | 09:16 PM
KTeller8's Avatar
2300 is that a bit much.. the nissan guys here got theirs for 1900 shipped for a Blue bird??
FREE BUMP
Old Aug 17, 2002 | 10:04 PM
g's integ's Avatar
Default Re: Again! Complete legit SR20 $2500 front clip *S13* and others. (KTeller8)
this is a front clip w/ everthing u need.
Old Aug 19, 2002 | 08:08 AM
g's integ's Avatar
up
Old Aug 19, 2002 | 02:40 PM
g's integ's Avatar
bump
Old Aug 19, 2002 | 03:23 PM
94mugenintegra's Avatar
Front Clip = Hood, fenders, lights, motor, tranny, ecu, ect.... correct !
Old Aug 19, 2002 | 03:41 PM
g's integ's Avatar
Default Re: Again! Complete legit SR20 $2500 front clip *S13* and others. (94mugenintegra)
It's all there....
Old Aug 19, 2002 | 06:28 PM
93b18civic's Avatar
do you have pics of the jdm gsr clip??? i am interested for that price. lmk.
Old Aug 19, 2002 | 07:30 PM
g's integ's Avatar
Default Re: Again! Complete legit SR20 $2500 front clip *S13* and others. (93b18civic)
soon I will
Old Aug 19, 2002 | 07:49 PM
avividmemory's Avatar
hey gil, did levi ever get back ahold of you?? i know our guy with the 240 still is very interested...just trying to work out the money...
Old Aug 19, 2002 | 11:22 PM
g's integ's Avatar
Default Re: Again! Complete legit SR20 $2500 front clip *S13* and others. (NoPowerAllRice)
Just give me call.
Old Aug 19, 2002 | 11:33 PM
HybridGSR1's Avatar
got a pix of the front end? the s13 body panels..
Old Aug 20, 2002 | 02:55 PM
g's integ's Avatar
up
Old Aug 20, 2002 | 03:02 PM
93eg-EKhybrid's Avatar
How about a price on a full front clip including dash and guages for a 88 or 89 civic HB? I would also like it without the motor and tranny if that is possible.
Old Aug 20, 2002 | 03:11 PM
g's integ's Avatar
Default Re: Again! Complete legit SR20 $2500 front clip *S13* and others. (89B16HB)
hmm that's tough one, might be possible
Old Aug 20, 2002 | 03:20 PM
stripped 95gsr's Avatar
fwd blue bird swaps cost less than the rwd silvia swaps , 2300 is not bad if all the body panels are there!
Old Aug 20, 2002 | 03:22 PM
Default Re: Again! Complete legit SR20 $2500 front clip *S13* and others. (stripped 95gsr)
well just let me know when you figure out a price thanks.
Old Aug 22, 2002 | 07:24 PM
93b18civic's Avatar
just wondering if you have pics of jdm gsr front clip. i im'd you but no responce
Old Aug 23, 2002 | 06:58 AM
Precision DC4's Avatar
Old Aug 23, 2002 | 07:20 AM
g's integ's Avatar
Default Re: Again! Complete legit SR20 $2500 front clip *S13* and others. (dc4-boosted20)
update.....Pics will be posted. Sorry for the dealy guys, so much orders are coming at me.
Old Aug 23, 2002 | 07:24 AM
Malachi's Avatar
got the stuff wednesday! thanks a ton, i'll let you know when its running.
da9blk1
Jun 26, 2007 05:51 PM
da9blk1
Jun 25, 2007 09:05 AM
JoeyLeet
Feb 20, 2006 02:08 PM
Si Shane
Aug 2, 2005 05:41 AM
g's integ
Aug 14, 2002 09:16 AM
