Oil cooler
Old Apr 16, 2009 | 07:43 PM
ITR-EKcoupe's Avatar
Default Oil cooler
i have a semi built ITR block. the usual forged H beams, forged pistons on stock sleeves. when i bought the motor it had a spun rod bearing and there was some definate shavings. can i or sould i reuse the stock oil cooler attached to the filter? or is there a way i can delete it? is it necesary or beneficial to the motor now that it has forged internals? im kinda weary putting something that possibly has shavings onto my motor thats fully rebuilt.
Old Apr 16, 2009 | 07:44 PM
Default Re: Oil cooler
oh ya the motor will be boosted. shooting for around 375-400 whp
Old Apr 16, 2009 | 07:57 PM
InvaderTrax's Avatar
You can delete it by not running the coolant hoses to it and just loop them around
Old Apr 16, 2009 | 09:04 PM
im scared there might be shrapnel/shavings inside the cooler itself which might contaminate my oil. any way of just not running the cooler on the block?
Old Apr 17, 2009 | 04:11 AM
kyden's Avatar
just get another one. they're cheap enough used.
Old Apr 17, 2009 | 10:51 AM
is there any way i can just not run one?
Old Apr 17, 2009 | 09:35 PM
Keep in mind there are two parts to the cooler. The part for the coolant and for the oil. They're both very simple and easy to clean if you're worried
Old Apr 18, 2009 | 11:50 PM
fourthgenhatchB17's Avatar
To delete it is simple. Remove the unit and buy the male threaded fitting for the block (its the part that the oil filter will screw onto). For example, the 99SI did not come with a cooler so you can source the part using that car as a reference when you go to Honda. Also, you need to cap, re-route, or plug the coolant hoses that are no longer used.
97CWITR
Mar 19, 2011 07:27 AM
ITR-EKcoupe
Aug 22, 2008 05:23 AM
Takumi Fujiwara
Sep 13, 2005 12:26 PM
riceball777
Jan 23, 2004 11:18 AM
riceball777
Jan 21, 2004 06:19 PM
