how can u tell obd1 and obd2
Old Apr 16, 2009 | 07:13 PM
97hatchgsr's Avatar
Default how can u tell obd1 and obd2
i dont have any idea to know how to tell the difference between the two is there an easy way to figure this out..?
Old Apr 16, 2009 | 07:25 PM
ITR-EKcoupe's Avatar
Default Re: how can u tell obd1 and obd2
what part are you trying to figure out? if your looking at a swap look at the numbers stamped on the head. thats usually a good way to tell what year it was made in, and by that you can figure out the OBD stuff.
Old Apr 17, 2009 | 09:38 AM
97hatchgsr's Avatar
ya i just want to know what year is in the car and what wiring harness it has
Old Apr 17, 2009 | 10:04 AM
mouab18c1's Avatar
to determine the ecu it should state on the ecu and the difference between harness's is obd1 harness has to plugs for your distributor obd2 only has one..since you dont specify what your looking for
Old Apr 17, 2009 | 11:39 AM
97hatchgsr's Avatar
ok what do i look for then
Old Apr 17, 2009 | 04:41 PM
Blown90hatcH's Avatar
Look at the ecu plugs.....if they are gray colored only and only two rows left to right of pins....OBD1. FYI, there is also OBD2a and OBD2b.....more info...courtesy of my friend Katman....
OBD1:
http://technet.ff-squad.com/wiring.obd1.htm
OBD2a:
http://technet.ff-squad.com/wiring.obd2a.htm
OBD2b:
http://technet.ff-squad.com/wiring.obd2b.htm
white2draccord
Nov 10, 2008 08:15 PM
19CivicSi99
Jun 17, 2007 03:29 PM
Panda hatch
10
Jun 13, 2007 07:28 PM
10seconds
May 16, 2006 04:08 PM
3s0n3
Mar 8, 2006 09:42 AM
