ls rebuild with gsr crank
Old Apr 16, 2009 | 07:10 PM
leroyb's Avatar
Default ls rebuild with gsr crank
im rebuilding a ls going to boost when im done but using all stock parts because i wanna bar the motor, my question was with a gsr crank will it make a diff in power and at the reff station??
Old Apr 16, 2009 | 07:16 PM
Turbo-LS's Avatar
Default Re: ls rebuild with gsr crank
WHAT ?????????? you wanna bar the motor????? power at reff station??????
Old Apr 16, 2009 | 07:43 PM
leroyb's Avatar
o should of stated every thing well i want my motor to be street legal, and about the power im running a 14b on the stock ls will a gsr crank help me make more power or should i stick to the stock one???and if i leave the gsr crank will it make me fail smog at the reff station
Old Apr 16, 2009 | 09:19 PM
SD_Lurker's Avatar
HT White Ops
No, a GSR crank will yeild you less power due to the smaller stroke. The GSR crank will have no negative effects on the ref. If you use a GSR crank your going to need to change the rods and pistons.
1SLaMMeDC2
Jul 22, 2010 10:14 AM
GSR615
16
Jun 16, 2010 09:16 AM
Ricextacy
Feb 20, 2009 07:29 PM
AllMotorEmptiness
May 3, 2005 01:07 PM
Racermech
Dec 29, 2004 03:40 PM
