Help! Stuck in 4th gear!
Well long story short. I bought this car. I know the previous owner. He claimed what happened was he was hauling ***, and as he was slowing down to a red light he put the shifter into first (he said he had to bang it in pretty hard) gear, but didnt let out the clutch. He said there was a loud pop or bang, and now the shifter is STUCK in 4th gear. The only thing that works is the clutch and slipping the clutch to about 10mph.
He claims the flywheel came off and smashed **** up, and it needs a new tranny. Of course, he's been known to be VERY wrong before.
Any other info as to possibilities before I buy a new tranny?
If it is the tranny, where can I get one cheap?
Thanks
Matt
_____
Thanks
Matt
_____
My guess is that he probably destroyed a selecter fork (or/and more), and that transmission will need a rebuild regardless. You'd be better off finding a used transmission with lower mileage from a junkyard (See FAQ's for junkyard search engine).
Sigh...
See the portion that says Honda OEM. Look below it... and voila! The link under the word "Used".
Thanks matt! I found one for a great price!
JDM freak- I might consider that. We'll see what the shop has to say about everything
Another quick question.. which year transmission will retain the stock tranny in my 05 EX special-edition? Does it ONLY have to be an 05? Because I'm seeing some 01's for my car, but dont know if they are different from my EX s-e tranny
F that. Now paying that much lol
That's not what I typed. I stated that you have to have a transmission of the same year as the production year of your bike. You don't have to go out and buy a new one from Honda, you just need to make sure it's from the same year.
Oh. Well NC is pretty damn lenient and easy as far as inspection (as long as your cel isn't on), but thats good info to know!
Also thanks for the link.. I found a pretty badass priced trans.
So the dealer thinks it might either be the clutch or the linkages. Which makes sense, since I've had a GST w/ popped off linkages that did the same thing.
Where are the linkages, and how do I remove the center console cover so I can look down there?
Wow this car has the goofiest shift linkage on top of the transmission I've ever seen lol. Some little black piece of plastic/metal/whathaveyou that goes up and down and side to side. It's moving, but I dont know correctly.
I took it to our post hobby shop, and the post mechanic thinks that the 1-2-3 synchromesh is gone, since the car is stuck in 4th gear, but if I jimmy it I can get it into 5th gear.
I'll check the how-to section, thank you.
That's only for emission's equipment and even that is sketchy at best.. They just don't want people in a 2000 EX using a '96 Intake Manifold because the '96 doesn't have the same warmup procedure as the '99-'00, and therefore emits more emissions. So while the engine itself should be excluded from this if everything matches, it doesn't because they potentially can lookup the block ID and see it's too old for that year of the car. They would NEVER do this for a transmission however so the OP is perfectly fine.
85_305
Transmission & Drivetrain
May 21, 2009 02:28 PM
miamiboy91
Apr 16, 2009 04:26 AM
dohcdelsol
Jan 7, 2005 10:11 PM
