Wiring help, which wire goes to CEL in cluster?
Old Aug 15, 2002 | 12:33 PM
B18EG6's Avatar
Default Wiring help, which wire goes to CEL in cluster?
Hi-
95 civic DX no tach in the cluster. Which wire goes to the Check Engine Light on the harness in the back? Or rather, since im lazy...where can I find the wire on the ECU?
Old Aug 15, 2002 | 12:35 PM
poison's Avatar
Default Re: Wiring help, which wire goes to CEL in cluster? (B18EG6)
damn, have the exact colors at my house if no one responds with the colors i'll post 'em for u.
they are the same color from the actual CEL to the ECU though.
Old Aug 15, 2002 | 12:38 PM
B18EG6's Avatar
Default Re: Wiring help, which wire goes to CEL in cluster? (poison)
yeh i know, thats why i think im going to tap it at the ecu not the cluster cause im way too lazy to rip it out of the ac vents and all that
Old Aug 16, 2002 | 12:24 AM
Extent's Avatar
Here is the wiring codes for the Civic cluster at least, if that's any help. Green/Orange is check engine light
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
3. grn/yel right turn
4. grn/blu left turn
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
3. NOT USED NOT USED
4. NOT USED NOT USED
5. grn/org check engine indicator
6. blk ground
7. yel/grn coolant temp
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
Old Aug 16, 2002 | 10:06 AM
B18EG6's Avatar
Default Re: Wiring help, which wire goes to CEL in cluster? (Extent)
you are a god.
thanks
b18eg6
Old Nov 20, 2004 | 04:13 PM
dornon13's Avatar
does anyone know if this is the same for a 98 ex? i dunno since they are prolly diff obd's
Old Nov 20, 2004 | 06:40 PM
BlueIntegraBoy's Avatar
Default Re: Wiring help, which wire goes to CEL in cluster? (dornon13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dornon13 &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know if this is the same for a 98 ex? i dunno since they are prolly diff obd's</TD></TR></TABLE>
Yes, same green/orange wire for the CEL.
Bluegixxer1k
15
May 26, 2011 01:32 PM
e jay one
Jan 24, 2007 02:31 PM
lsismore
Jan 13, 2006 01:14 AM
jbs
Dec 5, 2003 09:12 AM
The G2 Racer
Oct 18, 2002 02:38 PM
