Pulled my Engine
Old Apr 16, 2009 | 11:17 AM
scorp965's Avatar
Default Pulled my Engine
Rear Head removed:
Car has 106k miles:
Head Gasket in OK shape:
Front head still in place:
Rear Head off the Block:
The culprit, leaky exhaust valves on Cylinder 6:
C30A:
Both Heads off the Block:
Old Apr 16, 2009 | 11:38 AM
Chiodos's Avatar
Default Re: Pulled my Engine
Old Apr 16, 2009 | 12:34 PM
brandonEM1's Avatar
nice... Whats your plans for it?
Old Apr 16, 2009 | 01:30 PM
PSU's Avatar
PSU
formerly DxHatchback
Old Apr 16, 2009 | 08:48 PM
scorp965's Avatar
Taking apart the bottom end (engine/trans split)...
Some extra junk:
Transmission:
Heads already back from the machine shop:
All new gaskets, two exhaust valves replaced:
Second head:
Piston/rod assembly removed from #6 cylinder:
Old Apr 16, 2009 | 08:58 PM
scorp965's Avatar
I had a leaky exhaust valve on cylinder #6 which would blow oil when coming off of boost, I also found 20% blow by on the same cylinder.
I am installing new rings, new head gaskets, ARP head bolts, and am also gutting the VVIS system, which is a restriction on boosted nsx's. At the same time, a new clutch, lightweight flywheel, and four-wheel big brake kit are being installed.
Old Apr 16, 2009 | 09:23 PM
slowman's Avatar
I took way too long
Looks like a big undertaking! Neat to see pics of NSX engine removed though, never seen it.
Old Apr 16, 2009 | 09:42 PM
scorp965's Avatar
For engine removal, the entire rear sub-frame needs to be unbolted (as you can see in the above pictures), this is also somewhat required for items such as clutch replacement (not the entire sub-frame, but a portion of it), this is why a clutch job on these cars is an expensive undertaking, around $2500. Because these components are aluminum, air tools cannot be used for removal or assembly, as they could easily damage the thread.
Old Apr 16, 2009 | 09:56 PM
crazydominicanman's Avatar
Wow. Sweet.
Old Apr 16, 2009 | 10:21 PM
faster Type R's Avatar
more pics!
Old Apr 16, 2009 | 10:43 PM
phazedd's Avatar
im in for the subscription nicee dude
Old Apr 17, 2009 | 05:24 AM
KevonN's Avatar
I has a crayon!
sweet I can't wait to see the outcome.
Old Apr 17, 2009 | 09:51 AM
SlammedDC2teg's Avatar
Nice!!
Old Apr 17, 2009 | 05:56 PM
RMOracer34's Avatar
Wow. I dont think there has ever been a NSX build thread on H-T. Correct me if wrong.
Old Apr 17, 2009 | 06:01 PM
JdmDreams503's Avatar
Wow!
spideymangDC4's Avatar
damnnn more progress please! and thank you hahaha
Old Jun 13, 2009 | 06:50 PM
scorp965's Avatar
New pistons installed, new rod bearings, new ring sets:
VVIS plate has been gutted, then sandblasted; variable intake butterflies removed, casting ground down, entry points for butterfly shafts removed and filled in with aluminum:
Engine back together:
New Brakes (old brakes on top, +2" diameter):
Old Jun 13, 2009 | 08:25 PM
cetcivic's Avatar
no one wants to hear the truth
ooh nsx
soundquest
Sep 22, 2017 03:25 AM
sh!ft
Appearance Build Threads
12
Nov 10, 2014 06:34 PM
fitbkeco
Mar 11, 2013 06:27 AM
EH3SiGRL
35
Apr 5, 2007 01:07 PM
gheydeem
Oct 5, 2002 10:15 PM
