need help Daily driver wont start !!!!!!!!
Ok so I don’t get it I had wiring problem so me an a friend rewired the whole car (90crxwithd16z6 obd0) got it running good but the head gasket blew so the next weekend I started the car ran fine minus a blown head gasket so I took it a part changed the head gasket an put it all back together an now it wont run im not getting any codes it will try an start but wont the fuel injectors are not getting signal to pulse I checked all my ground an got a new main relay an both fuse boxes an checked all my wiring I don’t know what else it can be any help would be great thank you.
how do i check the ecu an i tryed a nother ecu i had still the same thing im going to try my friends this weekend any other ideas
i would try one that you know works for sure so if your friends is working on his car then try that for sure.
and are you sure the injectors are the only thing wrong? any other symptoms?
patrickd_21
Oct 14, 2009 07:19 AM
