d16y7 not starting need help!!!!
Old Apr 16, 2009 | 09:34 AM
gsrboost737's Avatar
Default d16y7 not starting need help!!!!
well this is the story my friend is swapping a y7 into his ek cause its gng to b his wifes car so we did the swap connected every sensor and when we tried to turn on the car it just cranks but doesnt start we checked the fuel the pump is working fine we checked the spark and there is we checked the grounds they r connected. when we checked the spark plugs we noticed a little oil in on of them could that be the problem for not starting
also if u dnt have the original ecu will it start?
thanks for ur help
Old Apr 16, 2009 | 10:55 AM
Former User's Avatar
Default Re: d16y7 not starting need help!!!!
Compression test the cylinders and check the mechanical timing.
Is the CEL staying ON with the key in?
Old Apr 16, 2009 | 10:57 AM
jjwolfcub2000's Avatar
what kind of ecu did you put in?
Old Apr 16, 2009 | 12:16 PM
i dont have the p2e i have a p28 and p06 do i really need the p2e to get it to start? the car cranks but wont start ...
Old Apr 16, 2009 | 09:12 PM
EGhatch87's Avatar
Have you checked the timing?
Old Apr 16, 2009 | 09:18 PM
sp00ledbseries's Avatar
get the rite ECU
Old Apr 16, 2009 | 11:38 PM
cloudconnected85's Avatar
sounds dumb but the plug wires hooked up right at the dizzy or timing off 180 at the crank
lt1guy
Feb 14, 2010 07:06 PM
McLovin
25
Nov 5, 2009 10:44 PM
El Boricua
Apr 7, 2008 04:13 PM
Rease3
15
Mar 3, 2008 07:32 PM
pvt_awol
Oct 14, 2007 12:25 PM
