Suspension & Brakes Theory, alignment, spring rates....
Replacing my Skunk2 coilovers. What to get next?
Old Apr 16, 2009 | 09:14 AM
D3vin's Avatar
Default Replacing my Skunk2 coilovers. What to get next?
I finally saved up around 6bills for a replacement. I have gotten the Skunk2 coilovers for free as part of a deal with my friend. They were used and now my front left spring seems to be sagging no matter how much I am raising the height on that end, but I am also running stock shocks. The ride is horrible but the handling is pretty decent except the bounciness scares me whenever I take turns and I roll over a little bump.
Since, I just got my 98 Civic 4dr for about a year I don't know much about tuning suspension. What is a cheap set up I can get (shocks/springs or coilovers) that is a bit softer than the Skunk2s and still stiff enough to have fun with? Right now, my car is lowered to 1 finger gap in front and 1 1/2 for my rear. I do not plan to go any lower for I will be scraping driveways or hills where I live.
My budget is $600.
Old Apr 16, 2009 | 09:57 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Replacing my Skunk2 coilovers. What to get next?
Save up 2 more bills and get GC/Koni, or maybe GC/Tokico Illumina for 1 more bill.
Old Apr 16, 2009 | 10:07 AM
BoostedxEk's Avatar
GC/Koni
Old Apr 16, 2009 | 10:09 AM
stevieteg's Avatar
I'm with them
Old Apr 16, 2009 | 02:32 PM
alexm's Avatar
Koni/GC are sick, but suck for being slammed. I had them last year on my slammed EG and I was always bottoming out. If you want to slam, get a fully body coil system.
Old Apr 16, 2009 | 02:43 PM
STOCK_SOHC_DX's Avatar
even full body coilovers will bottom out "slammed", KONI/GC
OP:but that's weird that your skunks went bad I have them on my APEXi N1 full body they work great. But yes they are getting replaced soon due to age of shock.
Old Apr 16, 2009 | 05:16 PM
Community Builder
Extended top hats should take care of that.
Old Apr 16, 2009 | 06:06 PM
D3vin's Avatar
HHmmm, GC/Koni... Koni yellow or red? I'm planning on keeping the same height as I am right now. Would Koni Reds/GC work? I don't think I would need to adjust my shocks.
Old Apr 16, 2009 | 08:15 PM
DC5DC2's Avatar
sorry to interrupt but what are top hats and how is it done, again i apologize for my rudeness n lack of knowledge
Old Apr 16, 2009 | 08:39 PM
Warhawk's Avatar
These are the top hats. The "extended" ones are taller and allow the shock to move up inside it more, allowing more travel!
Old Apr 16, 2009 | 09:41 PM
phatdroid06's Avatar
where can i find sum of these
Old Apr 16, 2009 | 09:48 PM
omnirage's Avatar
They allow more travel but you're still going to bottom out on soft *** springs. I'd imagine 330lb/in springs would keep you safe, unless your header hangs low like mine.
I can't run below 430lb/in springs up front, or else my header will be molested by Mr. Pavement.
Old Apr 17, 2009 | 01:15 AM
punkdown's Avatar
If I was you I would get some Koni Yellows for like 500 and see how they work with the S2 coilovers.
Old Apr 17, 2009 | 02:02 AM
bmoua's Avatar
Top hats will help with bottoming out but the best thing to do is to run higher spring rates up front. GC's OTS rates are only 350lb/250lb.
OP, if your planning to drop close to 2inchs or more i'd go with a 400+lb spring rate up front. When i was running 10k/8k (539lb/448lb) spring rates, while dropped 2inchs+ all around, i had no problems with bottoming out. Ride quality was still barable for me, to others it might not.
Old Apr 17, 2009 | 05:06 PM
D3vin's Avatar
Okay, someone please answer my question about Koni Red/GC or Yellows/GC also what is S2 coilovers that "punkdown" above posted.
precisionsc54
Suspension & Brakes
Jan 4, 2010 05:58 PM
Brand
Suspension & Brakes
23
Apr 5, 2006 12:16 PM
EkR
Dec 14, 2003 04:51 PM
PhazedSI
Dec 10, 2003 09:42 AM
EURO_CL9
10
Oct 10, 2001 06:41 AM
