Dailing in cams: Equipment
I have a magnetic base dail gauge, degree wheel and piston stop.
How do I attach this gauge to the head?
What do I use to lock the VTEC rocker arms to check V2V clearances? (tried swapping the pins but that locks the valves diagonally)
It's S2 Pro2's going in a unshaved ITR head w/OEM gasket, OEM sized valves and stock height pistons. I was thinking I should just use Skunk2's quick setting and be done with it.
Opinions, advice?
Opinions, advice?
http://s8.photobucket.com/albums/a43...t=S5000180.jpg
http://s8.photobucket.com/albums/a43...greeing006.jpg
Reverse the pins to lock VTEC. use the opening and closing numbers @.040 and do the math to find the centerline.
xyzalvarez
Dec 1, 2005 11:13 PM
lsvtec101
Dec 5, 2003 01:20 PM
