03 CRV check engine light help!
Hi guys, my GF's 03 CRV's check engine came on this morning after a cold night.....car drives completely normal, any ideas? Any inputs are appreciated! Thanks!
If you don't own a scan tool tp retrieve the code you can go to most autoparts stores to use one in their parking lot.
Or if you want to purchase one, Harbor frieght sells one for ~$30. Its very basic but it works fine. It will only read the code though, you'll need to look up the description.
re-read this guy's reply:
or you can just drive it as is & the gas cap light should go off after a few cycles
