Head gasket puzzle!
Old Apr 16, 2009 | 06:03 AM
cctgene's Avatar
Default Head gasket puzzle!
My son has a 1991 Honda, 225,000 miles, that has most of the indicators that it has a bad head gasket - disappearing radiator fluid, water dripping from tail pipe, stumbles at initial start up with a little white smoke then runs fine. However, it still has good compression, 175 across all 4 cylinders. I've changed more than a few head gaskets over the years, but I don't recall ever having a bad head gasket with out also having low compression. Is there something unique about Honda head gasket or am I having a senior moment. How is this possible?
Old Apr 16, 2009 | 07:56 AM
notAdiesel's Avatar
Default Re: Head gasket puzzle!
is there oil in the rad fluid?
Old Apr 16, 2009 | 08:00 AM
jweller's Avatar
Not sure of your background, but if you come from a domestic iron background, honda HGs and blocks are different than what you are used to. They are a open deck design with a multi layer steel (MLS) HG
Old Apr 16, 2009 | 08:21 AM
gasha1's Avatar
Do a leak-down test to find which cylinder is affected. It sounds like a hair-line crack or a very small leak in the gasket. Also check and compare the plugs.
Old Apr 16, 2009 | 08:59 AM
jhondayang's Avatar
easiest way, is to do a block check. when honda heads heat up due to a overheat, they tend to warp very easily. I'm assuming bad head gasket. I touch honda's everyday, and see these things.
johnsona76315
Honda Civic (2001 - 2005)
14
Apr 8, 2011 01:43 PM
skUnK2jdm
Jan 30, 2007 05:36 AM
redcivic
Apr 22, 2003 03:54 PM
00ITR #543
Aug 23, 2002 05:47 AM
