Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
element clutch problems
Old Apr 16, 2009 | 05:21 AM
marcin's Avatar
Default element clutch problems
The car is a Honda Element '05 manual 5 speed. 88k on the odometer. All standard maintenance performed and never touched clutch,etc. clutch fluid level is ok.
Today when i got into the car i could not go into gear once it was started(fine when its off). i figured something with the clutch and got it started in first and got to my first appointment. I had to clutch-less shift on the way there. Turned the car off there and went in. out a few mins later. start the car and no problem putting into gear. I continue not to have any problems until i get home about 1 hour later.
About 2-3 hours later go to get in the car. same problem but slightly better. will barely go into second and hard to get between gears.
I'm hoping its just a bubble in the system. i plan on starting by doing a bleed and going from there. I find it odd that the problem is intermittent. just curious if anyone had any other input.
thanks
m.
Old Apr 27, 2009 | 11:26 AM
marcin's Avatar
Default Re: element clutch problems
seemed to fix the problem by bleeding the clutch.
thanks
m.
Old Jun 5, 2009 | 11:19 AM
marcin's Avatar
came back after a day.
the issue was a broken spring in the clutch.
had to replace clutch to fix.
m.
headrec*
10
Dec 5, 2007 11:44 AM
esoterEK..
Oct 5, 2003 09:19 PM
hecklervtec
Sep 10, 2002 08:57 AM
Drew M
Mar 3, 2002 05:56 PM
