Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
95 Trooper problems off the line!
Old Apr 15, 2009 | 07:40 PM
B18CYAAA's Avatar
Icon6 95 Trooper problems off the line!
(puts on flame suit)
I am the proud owner of a 1995 Isuzu Trooper (brick on slinkies) AT w/ 116k miles. Something isn't right. About two days it began stumbling when I would give it gas. Almost like it was running out of gas, but it's not. I notice it mostly on the highway. So I tried driving around in third, on backroads, and the problem seemed to go away. However, when I drive at speed in drive it still stumbles, bucks, lags whatever you want to call it. Is it something to do with the fuel injection? How about the tranny? I keep up on regular maintance but I haven't done the timing belt. I am flirting with disaster as far as that goes. Thanks
Old Apr 15, 2009 | 07:45 PM
dirrtybirdy's Avatar
Default Re: 95 Trooper problems off the line!
timing belt? ionno im not a mechanic
i got that feeling the night my timing belt snapped. it felt like it wasnt going when you gassed it right?
Old Apr 15, 2009 | 07:49 PM
nbcivic's Avatar
your car was still going after that belt snapped?
Old Apr 15, 2009 | 07:51 PM
B18CYAAA's Avatar
yah exactly, it would pause a few seconds then begin accelerating. on/off/on/off.
Old Apr 15, 2009 | 08:33 PM
Splat's Avatar
Collector-o-Guns and Drinker
Do a basic tune-up. Cap, rotor, plugs. Does it have mass-air? If you can, remove the meter and clean it with electrical parts cleaner.
Old Apr 15, 2009 | 08:37 PM
B18CYAAA's Avatar
No, I don't believe it has mass air meter. Those are mostly on newer cars right. I mean the thing is OBD1. Better to spend the money on a tune up or break down and do the Timing belt?
Old Apr 15, 2009 | 08:40 PM
smileycvc's Avatar
LOL at timing belt causing bucking. Either your timing belt is broke and you dont move at all or your timing belt is fine and your car drives. Its not an on/off thing. Check your 02 sensors.
Old Apr 15, 2009 | 08:48 PM
B18CYAAA's Avatar
You didn't read what I wrote in the proper context. I am aware that once you snap your timing belt you can bend a valve etc. In my case my car becomes scrap metal. I said it's on/off/on/off referencing the way my car acts when I hit the gas. I know a timing belt can slip too if it's not on correctly/worn out. I'm just making sure I don't get stranded tommorow.
Old Apr 21, 2009 | 12:37 PM
ricebike's Avatar
what are your trouble codes?
http://www.troublecodes.net/isuzu/
changed out the fuel filter?
checked out the vacuum hoses?
what size engine?
if you have the 3.2L engine, you don't have an interference engine, so you can put a hold on that...
if you have the 2.6 L engine, then worry about bending valves when the timing belt does snap
xenoxnty
Mar 23, 2004 11:55 AM
GSRpower
Dec 30, 2002 08:16 AM
GSRaCeRbOI
Oct 22, 2002 06:34 PM
