Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
wheel alignment cost
Old Apr 15, 2009 | 07:14 PM
erdosain112's Avatar
New User
Icon6 wheel alignment cost
I have a 2001 honda civic ex coupe
The right front wheel hit a pavement at low speed a few months ago. I 've been driving it normally since. My new mechanic noticed the wheel is misaligned and suggested a 4-wheel alignment (I should have done it a long ago probably)
His quote is $90 for the wheel alignment itself, which sounds ok I guess. But he is also charging me an extra $90 and $30 for 2 camber caster bolts (see below for price quote). I just wonder if this is a normal thing to pay for when the wheel appears to be damaged? Is the bolt only used for the measurement or is it part of the wheel? Should he already have it and not charge me for it?
$89.95 4 WHEEL ALIGNMENT
4 WHEEL COMPUTERIZED ALIGNMENT INCLUDES: CHECK TIRE PRESSURE, CHECK WHEEL RUN OUT, INSPECT STEERING LINKAGES & SUSPENSION COMPONENTS FOR WEAR OR DAMAGE.
CHECK PRESENT ALIGNMENT CONDITION, ALIGN REAR & FRONT TO SPECIFICATION. (REAR WHEEL & 4X4 SHIMMING & CAMKITS EXTRA)
$93.63 R&R RIGHT FRONT CAMBER CASTER EC BOLT
$30.02 ECCENTRIC CAM BOLT
Submodel:EX; Crank Adjusting Bolt Camber Plus or Minus 1 1/4 Degree For Replacement Of 14mm Bolts
thanks
Old Apr 15, 2009 | 07:21 PM
toyomatt84's Avatar
Sanji
Default Re: wheel alignment cost
thanks
The R&R stands for "Remove and Replace". It's essentially the labor (time) cost to hoist up the car, remove the wheel(s), uninstall the crash bolts, and re-install the new ones (which are listed just below that price at $30.02).
The bolts are a bit pricey by Honda standards, but the labor is pretty accurate.
zeroluck
Suspension & Brakes
Jan 11, 2006 05:42 PM
h22 civic
Suspension & Brakes
Jun 11, 2005 05:44 AM
nygunrunners
Nov 3, 2004 03:54 PM
dyases
Jun 10, 2004 08:56 PM
Bklyn TSi
Nov 30, 2001 08:37 AM
