rusty bolts
i'm trying to replace my oil pan gasket but i can't get the two bolts that are holding my exhaust up. they are rusted so bad that penitrating oil wont even help. if anyone knows anyother way besides torching them off let me know.
Well, if there is no hope for breaking them loose, then yes I would torch them or use a die grinder and cut them off. On my D-series I didn't even have that bracket on, but if you want to use it you can always buy a new one or get one at the junkyard.
Are you using the penetrating catalyst "PB Blaster"? It is far superior to any other rust-buster. Soak the threads with this; drive for a few days; repeat application; drive. Then try to break them free, using a 5-foot or so pipe extension if needed and a good-fitting socket.
-illuzioN-
Sep 25, 2004 12:28 PM
