Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Rear Light Problem
Old Apr 15, 2009 | 11:32 AM
xxProjectMugenxx's Avatar
Default Rear Light Problem
So my main rear lights work but the ones that are on my trunk doent and either does my license light. I did change the bulbs and they were blown but nothing now. I have an 04 4dr civic. Any ideas?
Old Apr 16, 2009 | 08:21 PM
SoCalian_SD's Avatar
Default Re: Rear Light Problem
I have the same issue... any ideas anyone??
Old Apr 17, 2009 | 12:36 AM
I found the solution here
Originally Posted by online info
You have a broken wire inside the wiring loom that is zip tied to the trunk's right side hinge. It flexes each time trunk is open and there is a connection terminal where the wire breaks loose.
The wire color to look for is RED/YELLOW
The plastic loom is wrapped in tape so you will have to slice the tape to open the loom. When you find RED/YELLOW try tugging on it a bit coming from the front to back... You will find it will pull out quite easily. The break is further up in the trunk area.
It happened on my 05 sedan. I noticed one day while locking it that the tails on the trunk and the licence lights did not flash.
At the factory they tied about 3-4 wires going to a single wire with a crimp type sleeve.
It seems to only affect sedans.
Last edited by It Wasn't Me; Apr 17, 2009 at 07:22 AM. Reason: removed link (don't post links to competing forums) (anyone!)
k0ry_kayla
Lighting
Jul 27, 2009 04:59 PM
EcivicG
Lighting
Mar 6, 2008 08:45 AM
Celestion
Mar 7, 2004 07:08 PM
