Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Spacer to raise rear end...does it exist?! (CR-V)
Old Apr 15, 2009 | 10:52 AM
Mashimaro's Avatar
Default Spacer to raise rear end...does it exist?! (CR-V)
Hi guys,
I thought i'd post this here since this forum deals with the SUV's of Honda.
anyways, i'm searching for spacers like the pic below that go between the top-hat and the car body. Does anyone know if they ever made these for the CR-V? if so, who makes them? Thank you for any input you can provide
ps - this is for my EG. rear suspension is slammed and the spring is maxed out for height with the short-stroke damper.
Old Apr 15, 2009 | 02:19 PM
qwrty's Avatar
Default Re: Spacer to raise rear end...does it exist?! (CR-V)
can a spring helper like the one tein is selling works the same??
ive seen that spring helper online, it might work too?? i dont know
yet, but there are other members from hondasuv lifted their V's
doing a different route...
Old Apr 15, 2009 | 02:57 PM
Mashimaro's Avatar
^unfortunately for me, the shock travel is already maxed out and i'm only adding more preload to the spring
Old Apr 15, 2009 | 03:40 PM
civic95hbvtec's Avatar
pretty sure nobody make's them.
Try searching, "old man emu" they made lift springs for the CRV.
Old Apr 15, 2009 | 03:42 PM
Mashimaro's Avatar
damn...custom machine shop cnc it is then
Old Apr 15, 2009 | 04:19 PM
qwrty's Avatar
from the looks of it.....
look for a machine shop that could do it,
let us know...
good luck!
Old Apr 16, 2009 | 04:55 AM
Ross 2.0's Avatar
In a Junkyard near you.
The lift blocks can be made. I've seen them on a Ridgeline.
Old May 21, 2009 | 08:16 AM
Mashimaro's Avatar
UPDATE!
problem solved, custom CNC'd spacers and extended studs were made thanks to my local shop (Evogarage)!
on with some pics:
Old May 21, 2009 | 08:31 AM
Splaturn's Avatar
That's pretty awesome, man!
Get before and after pictures for us.
Old May 21, 2009 | 08:33 AM
Mashimaro's Avatar
yah dood, i'm extremely impressed!
i don't have a really good aftershot as i just took a quick pic in the shop but i think you can see the difference...
before:
after:
stevenEK9
Suspension & Brakes
Dec 8, 2008 03:41 AM
Islandspeed
Suspension & Brakes
Mar 6, 2005 07:05 PM
lOOkatme
Apr 8, 2004 09:44 PM
austrian type-R
19
Nov 13, 2002 04:57 PM
ActiveAero
Oct 4, 2002 08:22 AM
