Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
How do you change the alternator belt?
Old Apr 15, 2009 | 09:25 AM
chinesebwoy's Avatar
New User
Icon2 How do you change the alternator belt?
I'm new to this forum and was wondering if anybody can tell me how to change the alternator belt. thanks
Old Apr 15, 2009 | 10:34 AM
daddy's Avatar
Default Re: How do you change the alternator belt?
The best way is to read the instructions in a chiltons or haynes manual.
But basically you take your drivers side front tire off to access where the belt goes around the crank pully
loosen the alternator to relieve tension on the belt.
pull the old belt off
put the new one on
adjust to the proper tension which i believe is around 0.4" deflection
put tire back on.
done.
Old Apr 15, 2009 | 10:37 AM
Boilermaker1's Avatar
missed a step in there...
Remove left front tire
remove splash guard
remove power steering belt (loosen the pivot bolt and then remove the adjustment bolt so the PS pump swings enough to free the belt)
Then loosen the alternator/AC tensioner pivot bolt, loosen the top alternator bolt and loosen/remove the adjustment bolt.
Swap belts, reverse.
Old Apr 15, 2009 | 11:27 AM
daddy's Avatar
forgot splash shield since i dont have them lol
thanks for filling in
Old Apr 17, 2009 | 01:47 AM
Maverick's Avatar
Team Purple
what he said. just dont cut the old belt off. its easier yes, but if somehow you bought the wrong belt youre stuck for a while.
el1cuban
Apr 18, 2009 10:10 AM
t_mac
14
Dec 21, 2008 01:20 PM
ATrin
Jul 4, 2008 09:05 PM
blackhope121
May 17, 2007 06:55 PM
519[H]Si
May 25, 2004 09:25 PM
