How do i know if its a GSR Shift Linkage and not a LS Shift Linkage
I would like to buy a shift linkage from a private seller. But my question is how do I know if whatever hes selling is from a GSR and not from a LS. I am doing a swap in my EG and would like to know. THank you.
i'm pretty sure everything is identical except for the shift ****.
with the exception of the gold R linkages
pretty sure they r all the same except for the piece the shifter screws onto. if its a gsr it will be bent looking. if its a ls it will be straight.....i own a gsr and my shifter is bent forwards a little bit, the way gsr's are supposed to be.
civics are the single bend back
I have all 3. the gold r is the same as the ls except bent down at the end where it bolts to the shifter.
the gsr is identical to the gold r but has a wider mouth where it bolts to the shifter
but i meant the fitment issue wouldnt be a problem right on an eg with a B18c1? I just wasnt sure if i can use all B series shift linkage on my b18c1 swap on my EG
I have a B16 about to take the place of a LS but I don't thave the hardware to attach it to the transmission. Anybody know if its the same (can i use the LS hardware?)
The B16 shifter (in the cab) is straight but my LS has a bend in it
full Circling
Jul 9, 2005 08:43 AM
