primary o2 sensor heater
Old Apr 15, 2009 | 08:44 AM
jjwolfcub2000's Avatar
Icon2 primary o2 sensor heater
i have a 95 ex coupe and my cel was on. I jumped the codes and code 41 came up (primary oxygen sensor heater). Is that just the upstream 02 sensor or is it something different?
Old Apr 15, 2009 | 09:06 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: primary o2 sensor heater
Since your car is an OBD1 car/motor, you only have ONE O2 sensor. Replace it with a new or used one (that is still OK). Try running higher octane gas and/or changing out your spark plugs so you won't deal with this issue in the future.
Old Apr 15, 2009 | 05:37 PM
thanks I know i only have one sensor but it said heater so i wasn't sure.
Old Apr 15, 2009 | 06:28 PM
civic_driver's Avatar
it's probably the heater element on the sensor itself. so you need a new o2 sensor (or your ECU is messed up but it's most likely the o2 sensor)
Old Aug 1, 2009 | 11:13 AM
EFLS89's Avatar
do you think changing the spark plugs can also eliminate the problem, i have the same problem, i changed the sensor and its still shows, im going to try another sensor from my freinds car that works and find out.. if not then maybe it could be the ecu
Old Aug 1, 2009 | 12:16 PM
Former User's Avatar
First check the power and ground wires for heater element of the sensor.
cnumb
May 4, 2017 06:03 AM
Mfkafka
Honda CR-V & Element
Mar 12, 2013 12:19 PM
apok
May 16, 2005 09:52 PM
cu3tip
Oct 18, 2004 08:26 PM
CereaLand
Jun 30, 2004 12:01 PM
