oil in coolant reservoir
Old Apr 15, 2009 | 08:41 AM
lakerschamp2000's Avatar
Default oil in coolant reservoir
what could go wrong when you see motor oil mix with coolant in the coolant reservoir?
Old Apr 15, 2009 | 08:58 AM
EL Vap133's Avatar
Default Re: oil in coolant reservoir
You should know this, you're a veteran around here. Is someone else posting under your account?
Well just in case it is you, usually that means that you have blown a headgasket. Did your car overheat recently?
Old Apr 15, 2009 | 09:20 AM
haha true that. haven't been working on car for awhile so don't remember much haha. well no overheated, no oil leaking from the head or block so not sure if that is the case
Old Apr 15, 2009 | 09:26 AM
instructor74's Avatar
if you have oil in our coolant you have one of 2 things going on either a blown head gasket, or a cracked block/head. I guess there is one other option someone put oil into the coolant reservoir
Old Apr 15, 2009 | 09:30 AM
MonkeyMagic's Avatar
there are only a few places coolant gets close to oil. and they are alll around the headgasket.
dry/wet compression test and a cooling system pressure test are in line for you
Old Apr 15, 2009 | 10:15 AM
i will check it later, also car losing lot of oil, about 1qt in 1 month
Old Apr 20, 2009 | 10:39 AM
head gasket maybe? there's some oil around the no.2 sparklug, not on the tip, where the shocket go in.
Old Apr 20, 2009 | 10:51 AM
Vindicator9000's Avatar
318 Curves, 11 miles
^^^^^ 100% headgasket.
jake28
Honda Civic (2001 - 2005)
Jan 15, 2014 10:06 AM
Corksil
May 8, 2011 08:34 AM
oranginal
Mar 30, 2009 07:39 AM
Raymund
Aug 8, 2003 07:41 PM
Halo
Aug 12, 2002 06:27 PM
