Cracks in weld areas (304 stainless)
What usually causes cracks directly next to the welds in 304 stainless constructions like downpipe or dump tubes?
Material is 304 with a thickness of 16g.
Or is the 304 not the perfect choise for these applications?
Maybe use 321 in the future?
Thanks
Thanks
Filler was enough - I´m pretty sure.
I usually weld these with 45-55amps.
Downpipe is always mounted with flex bellows, so vibrations should not be the problem.
The cracks only occure when and where I route the dumpetube into the downpipe and at the rear brace for the oem header mount behind the oilpan (honda B series).
The crack is directly next the weld - not the weld itself.
I never had a single problem with cracked manifolds or where I weld tube to tube.
More ideas?
More ideas?
Yes, that´s the amperage I use for 1/16 filler.
It seems to be a problem of thermal expansation as somebody stated before.
I started to do a little research on different materials used for that applications.
This makes me to think about carbite precipitation that comes when 304 is used....
But it´s hard to translate all the articles :-)
destroyer haha nice sig.
downpipes crack because guys dont go right through the material with the weld, so inside the pipe u still got a joint that isnt welded.
backpurge and check the inside of the welds for penetration!!
