Battery Jumped With Battery Wont Stay On
Old Apr 14, 2009 | 09:49 PM
vtec420kingH22's Avatar
Default Battery Jumped With Battery Wont Stay On
My stupid friend tried to jump my ef hatch by placing another battery on top of the battery on the car!
The car will start but it wont stay on! the battery light on the dash keeps flickering then the car shuts off!
Any ideas? How much damage could it have caused?
Old Apr 14, 2009 | 09:55 PM
barely4dr's Avatar
Default Re: Battery Jumped With Battery Wont Stay On
alternator
Old Apr 14, 2009 | 09:56 PM
pushinglikekrazy's Avatar
Well if it jumped the car.... that means he got the polarities right! As for damage 2 the car in theory nothing should have been damaged..... unless at one point he put it on reverse polarity.... but that could have also blown up the battery...... I think u need to get ur alternator tested..... check if its even putting out a charge..... and go from there
Old Apr 15, 2009 | 05:05 AM
Berkut99's Avatar
Has to be your alternator. I had the same problem with mine. The light will probably flicker then go off as you rev the engine. Go and pick one up at Kragen for like a hundred bucks.
Old Apr 15, 2009 | 05:29 AM
honda.lioness's Avatar
Originally Posted by vtec420kingH22
My stupid friend tried to jump my ef hatch by placing another battery on top of the battery on the car. The car will start but it wont stay on. the battery light on the dash keeps flickering then the car shuts off?
The battery icon on the light on the instrument panel is misleading. It is actually the charging system warning light, meaning the alternator or its wiring has failed somewhere. There is a good chance your friend did nothing wrong. Instead, your charging system cannot charge the battery. Some hints: http://honda.lioness.googlepages.com...alternatortips . Note especially the tip on only changing the alternator brushes. If the brushes are the problem, replacing them is cheap.
Old Apr 15, 2009 | 12:43 PM
Aristotle's Avatar
Alternator.
Old Apr 16, 2009 | 11:11 AM
Maverick's Avatar
Team Purple
most definitely the alternator. that and the battery could have been damaged as well. check both of those.
Old Apr 16, 2009 | 11:44 AM
redsi89's Avatar
I agree it's probably the alternator. sometimes you can have them rebuilt for $30 - $40.
yaaagin
17
Aug 27, 2011 06:01 PM
busha61067
Feb 10, 2010 04:54 PM
Vt3c_eg
Jul 15, 2008 03:16 PM
ef9one6
Apr 17, 2007 07:31 PM
biggdogg
18
Nov 26, 2003 06:32 AM
