all motor d16z6
Old Apr 14, 2009 | 08:36 PM
dirtyharryhatch's Avatar
A Digital Frontier
Default all motor d16z6
well my friend was interested in building his d16z6
kinda setup he wants is basicly
i/h/e
oem bigger injectors (what u recomend?)
pm7 pistons
a bigger cam (what u recomend?)
anyone have a similar setup?
what tranny should he use aswell?
Old Apr 14, 2009 | 08:59 PM
1.5Slowmatic's Avatar
Default Re: all motor d16z6
i/h/e
oem bigger injectors (what u recomend?)Stock is just perfectly fine but if your upgrading look into CBR injectors
pm7 pistonsid rather run PG6 pistons with the vavle reliefs cleareanced a very small amount
a bigger cam (what u recomend?)Lots of options here. For the money the zex 59300 is a great cam but theres also exospeed which is very cheap and good or bisimoto for the top of the line
what tranny should he use aswell?Stock z6 is fine unless he wants to play with the gearing. Than talk to mFactory for that
my opinions in bold
Old Apr 14, 2009 | 09:12 PM
A Digital Frontier
thanx thought id have to upgrade injectors cause of the CR
and it was between the pg6 and the pm7s he kinda wants to run high 11 to 12.1 CR
just saw the zex cam sound good but i dont think he wants to upgrade the valve train so i think he might go with the 59100
Old Apr 14, 2009 | 09:36 PM
nope stockers go to 200hp easily. as for the pistons, the PG6's sit zero deck so its a better starting platform, however Nippon p29s sit zero deck also but thats about 14:1 CR. Just mill about .02" off the head and your good to go. And you dont need to upgrade retainers, just springs. They are cheap and well worth it to run the bigger cam
Old Apr 14, 2009 | 09:42 PM
A Digital Frontier
what cam gear should he go with?
any good headers u recommend?
what u think this setup will make?
Old Apr 14, 2009 | 09:50 PM
well there are alots of options for the cam gears. AEM, Rage, UR, Bisimoto, Venom ect ect. They all do the same thing but the best one IMO is the evolution/bisi piece. 2 piece design, its very nice but expensive. The 50 dollar AEM would do just fine. As for the header, depends on his cash again. But id say just take a look at an ebay header with a 2in collector or mod the collector. If you have cash to spend, ASP makes a DAMN good header but its quite pricey.
Old Apr 14, 2009 | 09:53 PM
A Digital Frontier
i was thinking about an ebay header with a modified collector
looks like a fairly cheap build cant wait to let him know tommorow
uve been really helpful
Old Apr 14, 2009 | 10:05 PM
Jimster480's Avatar
what kinda power is he looking to make?
Old Apr 14, 2009 | 10:06 PM
no problem. make sure the head recieves a good valve job and some porting from someone who knows what they are doing wouldnt hurt either if the money is there. I think with just the basics listed above and a good vavle job you'd be looking at around mid 130's-140hp. more with headwork and a bigger cam
Old Apr 14, 2009 | 10:11 PM
A Digital Frontier
sounds good right now its all about the budget
chinovasquez92
Mar 15, 2015 06:34 PM
lilshady6796
Nov 2, 2008 05:21 PM
OPTIMUS
Mar 29, 2002 07:00 AM
