Help!!! Timing issue!
I just replaced my head gasket and I got everything back together but I'am running into the timing problem. When I line up the cam gears on TDC the intake side will jump a tooth or two. How can I prevent the cam gear from jumping?
Have someone give you a hand by holding the cam gears in place with a wrench, or use a center punch to keep the cams from rotating.
Have someone help hold the two cams with wrenches, or use a drill bit / center punch to hold the cams. These are located in the cam caps (some B-series don't have them though). Yours should.
And remember. Run the belt in this order: Crankshaft, tensioner, waterpump, exhaust cam, intake cam. Makes it cake. Should be only a little slack between the crank and exhaust cam, and between the exhaust cam and the intake cam. Then tighten the tensioner pulley and it'll be perfect.
sayanything
Dec 21, 2010 06:36 PM
DrGrEeNtHuMb
Jul 29, 2009 01:08 PM
