Cometic head gasket/cam gears
Im running a .074 Cometic headgasket on my turbo B16, and I understand this alters the cam timing...I have adjustable cam gears,....which way should I turn them to get the original timing back?.I'm thinking I should probably retard them a couple degrees but i'm not sure....
Re: Cometic head gasket/cam gears (StylishDOHC)
Your cams have alignment holes. If you put dowels through the top of the flat aluminum piece on top of the cam caps and through the holes, then it will lock them at TDC. So rotate your motor to TDC, loosen the cam gears, then rotate the cams until you can put the dowel through the hole, then lock down the cam gears, remove the dowels, and you should be all lined up.
Re: Cometic head gasket/cam gears (sc4dr)
right on...I thought those holes were only on LS heads for some reason...Iv'e already figured out that I need to retard them about 2 degrees though...Thanks guys...
