Suspension & Brakes Theory, alignment, spring rates....
buying used shock
Old Apr 14, 2009 | 11:45 AM
Duc_du's Avatar
Default buying used shock
i am planning to buy a set of used shock but i was wondering how do i check to see if it is blown or good condition? i dont want to buy them and put them on and end up mess up. Its tokico illumina and plan to use it with my eibach prokit
Old Apr 14, 2009 | 12:02 PM
stevieteg's Avatar
Default Re: buying used shock
Check the seal where the shaft retracts into the body and make sure its not leaking. Take the spring off the shock and compress the shock by hand. It should be difficult to compress throughout the entire stroke. It should rebound uniformly. Set it to its stiffest setting and do the same. Check the shafts and look for scoring. Any scoring can ruin the seal and ruin the shock. Check out all the threads. Make sure you get all the adjusters.
Old Apr 14, 2009 | 02:03 PM
TunerN00b's Avatar
Really, the only true way to tell if the shock is operating correctly is to dyno it.
The steps that stevieteg listed can identify a definitely blown shock, but they do not tell you for certain that the shock is still good.
Old Apr 15, 2009 | 04:52 PM
Duc_du's Avatar
thanks for the feed back appreciated
cleansi
Suspension & Brakes
13
Jun 3, 2012 06:59 AM
delacampos
Honda Motorcycles
Dec 4, 2008 03:37 AM
dfoxengr
Mar 15, 2008 07:41 AM
Wsteun
Oct 23, 2006 07:34 AM
eortizr
Aug 30, 2005 12:30 PM
