tech: cars eating oil
my 90 crx is eating a liter of oil like every 1-1.5 months
but when i rev it theres no white smoke or anything
any suggestions on what i should check ??
try replacing the pcv valve first..
cheapest route
mine uses bout a litre a month
it reduced my oil consumption a little
after that u can do a compression test and leakdown test
cheapest route
The pcv valve on the intake manifold. There is a hose from the top of the intake manifold to where the valve is. There are 3 hoses right in the center of the intake manifold up top. The one in the center will go straight to the pcv valve.
edit: pic won't work
[Modified by B16CRX, 12:21 PM 8/15/2002]
you may be running too rich a fuel mixture...this will cause the oil to dilute due to fuel running down the cylinders into the oil pan...which in turn would burn away but not cause white smoke as much as full on burning oil...causeing eating away of your oil. Does black powdery film appear on your rear bumper? that could be a sign of running rich.
superR303
Apr 23, 2002 05:06 AM
