Idle issue
Old Apr 14, 2009 | 07:07 AM
MIGPA26's Avatar
Default Idle issue
My rpms seems to jump up and down about 500rpms even when im at a light. I had this problem for about 2 months..
I put about 30000 miles on engine, in going to get new spark plugs, wires, cap and rotor..
Any suggestions??
Old Apr 14, 2009 | 07:43 AM
89s1's Avatar
Default Re: Idle issue
I suggest you search, this thread is made weekly.
IACV or FITV. look into it.
Old Apr 15, 2009 | 07:06 AM
MIGPA26's Avatar
Brand new iacv about 3 months back and fitv i took out and cleaned?
Old Apr 15, 2009 | 07:41 AM
89s1's Avatar
you don't sound very sure.
look more into the fitv, it needs adjustment, the iacv is the one you're supposed to clean.
where'd you get the new iacv?
Old Apr 15, 2009 | 07:46 AM
SquirtleSquadEf9's Avatar
did you put a aditive into ur gas??? like a OCTANE BOOSTER??? that would *** up ur idle air control motor
Old Apr 16, 2009 | 06:50 PM
MIGPA26's Avatar
no booster..
the iacv is the one that has coolant running threw it, and the fitv is one the front of intake manifold by the fuel pressure regulator..
I purchased a new iacv from ebay, was brand new...
Old Apr 16, 2009 | 08:52 PM
hmmm dont know wat to tell u than man haha sorry. i just changed mine and it worked normal. cause when i used to be on the freeway cruising speed it would just turn off haha.
Old Apr 17, 2009 | 02:07 AM
Maverick's Avatar
Team Purple
this is one of those times i wish i paid attention. someone brought a car with this same issue but i was busy with something else, from what i remember tho its something to do with a sensor. maybe someone can take it from here......
post back if you figure out what it is, im curious!
Old Apr 17, 2009 | 02:16 AM
~sp33~'s Avatar
EFB055
Mines had this problem for a while, It occasionally stops it, but more then often it comes back, cleaned the IACV and adjusted the FITV.
I don't see how the hell this would effect the IACV.
Old Apr 17, 2009 | 05:54 AM
JDMforlifeOH's Avatar
its your map sensor
Old Apr 17, 2009 | 05:57 AM
the problem should stop most of the time after the car has ran for awhile but some dont, but im highly positive its your map sensor
Old Apr 17, 2009 | 09:56 AM
YES YES YES NEVER USE OCTANE BOOSTER ON YOUR HONDA!!!! IT WILL F IT UP!!!! your car will idle funny it will go from 500 up to 1500
Old Apr 17, 2009 | 05:48 PM
~sp33~'s Avatar
EFB055
Shut up, damn.
What exactly is the problem with the map sensor? Or are you just saying to replace it?
Old Apr 17, 2009 | 06:01 PM
Originally Posted by ~sp33~
Shut up, damn.
im saying the wires to the map sensor can be somehow cut or damaged or the map sensor its self is bad. if you have a d16 try it. start it up and unplug the map sensor it will do what hes saying, i work on alot of hondas and the main problem with idleing is map or iac
Old Apr 17, 2009 | 07:56 PM
~sp33~'s Avatar
EFB055
I'm heading to the wreckers on Monday, hopefully i'll find a map sensor.
Old Apr 17, 2009 | 08:19 PM
if you get one make sure to get both the map sensor and the plug that goes into the map sensor as well,it only has 3 wires that run to it and change both and if it still contiues to idle funny check your wires from ecu to map sensor,
Old Apr 18, 2009 | 02:53 AM
~sp33~'s Avatar
EFB055
Righto.
Are MAP sensors fairly universal? Or should i try and stick with an OBD0 D series?
None of the OBD0 civics here where EFI, so I'm wondering if i could use an Integra or an Accord.
Old Apr 18, 2009 | 08:20 AM
im not sure, but to be safe id stick to the d series their not hard to find or around here their not
you could try using one from a teg or accord but i have no clue if it would work or not
Old Apr 18, 2009 | 03:07 PM
~sp33~'s Avatar
EFB055
I will if i can find one, but as i said, they're all carburetor here.
Old Apr 18, 2009 | 03:13 PM
lilsicsoul's Avatar
use the search ...
hinT** its in the faQs section!
Old Apr 18, 2009 | 03:17 PM
~sp33~'s Avatar
EFB055
Originally Posted by lilsicsoul
use the search ...
Did you read the thread?
Old Apr 18, 2009 | 05:42 PM
yea id deff try it wouldnt hurt, it might have a different plug but im not sure, i might try it cuz i need a new map sensor
Old Apr 19, 2009 | 12:51 AM
pushinglikekrazy's Avatar
My 2 cents....... wat exacty are ur rpm oscilattions? From wat rpm does it drop to and climb 2? Let's say its going from 600 to 1200 rpms...... with this scenario..... I would treat it as a vacuum leak..... idle is shooting high..... computer sees this thru rpm ...... looks over at the tps sensor to see its status....... sees that throttle plates are closed then says.... oooh crap idles tooo high I should attemp to correct and and drops the idle...... that's when it bogs out to 600 rpm....... wit that being said that's how the iacv can be defective in the open position causing a massive vacuum leak.... in relation that's why its a tipical fix.... veery common. Soooo wit all this being said I would look into a vacuum leak..... to start....... intake mani gasket, vacuum hose to the fuel regulator, brake booster..... etc...... another thing I've seen wit slight idle ossoscillation is dirty throttle bodys.... but that's usally couple houndred rpm only..... hopefully that helps keep us posted
Old Apr 19, 2009 | 11:00 AM
MIGPA26's Avatar
Doesnt do it all the time, will go from 1000rpm to like 1500rpm and will continue until i push the gas pedal and then stops. It doesnt do it everyday..
I was told the map sensor before becuase it has the stock d series which is on the firewall, i was the thinking of switchiing to the one that will be on the intake throttle body..
Would that be easy to do??
what will be involved.. I already have a throttle body made for it I was told to hook up the map sensor onto throttle body and it eliminates a vacuum hose ( IF I REMEMBER CORRECT)
thanks again everyone
Old Apr 19, 2009 | 03:34 PM
~sp33~'s Avatar
EFB055
^^ I have the same throttle body. I might actually see if i can get that one today.
I'll report back.
raverx3m
Aug 26, 2012 06:22 PM
fresheg760
Jun 7, 2008 06:33 AM
em1gangsta
Apr 3, 2008 12:14 PM
Mik3
Feb 5, 2006 06:55 PM
