stem Seals
Old Apr 14, 2009 | 06:35 AM
DC5BOI90's Avatar
Default stem Seals
Does anyone know where the stem cells go on an automatic 1990 crx?
Old Apr 14, 2009 | 06:42 AM
4drEF's Avatar
Keyboard Humorist
Default Re: stem cells
I can't even help you with a ashop manual on this one. When I search to try to figure out what a stem cell for an automatic is, I get stuff about chicken egg and embryos.
Old Apr 14, 2009 | 07:11 AM
apekd's Avatar
Stem cells....hmmmm...no such thing eh
Old Apr 14, 2009 | 07:25 AM
Black4thgenEF's Avatar
All this debate about fetuses and they could just be harvesting stem cells from the wreckers!
Do you mean stem seals, as in valve stem seals?
Old Apr 14, 2009 | 07:34 AM
aaronhume's Avatar
lol... hopefully a good catch
Old Apr 14, 2009 | 07:36 AM
4drEF's Avatar
Keyboard Humorist
Confusing if he meant stem seals.
I was looking all over in the transmission section as it seemed important to the OP to point out that it's an automatic
Old Apr 14, 2009 | 07:41 AM
Could just be an account left open on a public computer -- OP only seems to post in RSX/EP3.
Old Apr 14, 2009 | 07:42 AM
89s1's Avatar
Stem cells are a touchy subject, im staying out of this one
Old Apr 14, 2009 | 08:28 AM
detuned's Avatar
...ibtl?
Old Apr 14, 2009 | 09:10 AM
Ass$nyper's Avatar
Pirate General...YARRRR
I think you made a typo, or someone's pulled your leg.
I did chuckle.
gator88's Avatar
Originally Posted by detuned
...ibtl?
Most certainly!
Old Apr 14, 2009 | 11:37 AM
DC5BOI90's Avatar
sorry i was typing in a hurry i meant stem seals.
Old Apr 14, 2009 | 12:40 PM
4drEF's Avatar
Keyboard Humorist
K... assuming stem seals for the valves in the cylinder and not the transmission some place, right?
Will you be doing this with the head on the block, or will you be removing it?
Take a look at this, it's for aB-series, but it's just about the same thing minus a few steps (D-series won't have some parts)
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-%2A%2A%2A-install-valve-springs-valve-stem-seals-1604753/
If you leave the head on the car, you can buy an adaptor to hook up an air compressor to the spark plug holes. The air keeps the valves up while you work. You do not want them falling and then possibly chipping to dropping in and then you have to pull the head off anyway. If you don't have air, you can also rotate the crank so the piston is about 1/4 way down from being at top. Then feed a long length of nylon rope into the cylinder through the spark plug hole. Turn the crank to bring the piston up a little (don't go crazy) to compress the rope which will hold the valves up.
Old Apr 14, 2009 | 12:41 PM
mitsubishiv5's Avatar
Hahahaha
Old Apr 14, 2009 | 12:43 PM
4drEF's Avatar
Keyboard Humorist
Oh - a small magnet is good to keep track of the keepers and they make a few different types of tools for compressing the springs rather than using brute force like the link I gave above.
d_s2k
Honda S2000
Sep 4, 2009 03:18 PM
blackeg
May 1, 2007 01:59 AM
madjdmy0
Sep 15, 2005 11:20 AM
ACUHON
Jun 30, 2004 07:18 PM
