n00b air intake question/theory
Old Apr 14, 2009 | 12:09 AM
SupaMonkey's Avatar
Icon2 n00b air intake question/theory
So I was wondering, if cold air is good for an engine - then what is the problem with hooking up something like your aircon into your air intake to provide your engine with cool / condensed air for improved performance?
Old Apr 14, 2009 | 03:42 AM
GhostAccord's Avatar
Default Re: n00b air intake question/theory
Just a theory here, but it could be that running your air conditioning compressor. Negates the small power gains from the amount of cold air it adds.
Old Apr 14, 2009 | 04:40 AM
SupaMonkey's Avatar
yeah, it probably would, but what about an external unit not consuming power? Would the gains from pumping cold air in there really be that small?
Even if it was just enough gains to neutralise the negative effects of AC - thats not half bad?
Old Apr 14, 2009 | 05:39 AM
An external unit will still consume some sort of power be it electrical or mechanical. Or are you talking about a limited use setup, like a rechargeable electrical system? then weight vs HP gained will be your concern.
Old Apr 14, 2009 | 05:55 AM
fcm's Avatar
fcm
Old Fart
The theory is interesting, technicly a BCAI, B for boosted as the blower fan would increase pressure.
As mentioned, the gain would be offset by the loss due to the extra load, a CAI would be more effective, even though the air may not be as cold. 94
Old Apr 14, 2009 | 02:18 PM
TunerN00b's Avatar
Line the CAI with peltier coolers.
I'll wager you still lose more power running the alternator to generate the power for the peltiers than you gain by cooling the intake charge, but it could be interesting to see a sub 0* IAT.
bigsnorlax
Sep 12, 2008 04:59 AM
wm5holla
Jul 29, 2003 09:16 PM
00WhiteEKy
May 5, 2003 01:15 AM
mercforty4
11
Apr 1, 2002 04:41 PM
nsxxtreme
Honda S2000
Mar 15, 2002 05:01 PM
