N/A spark plug gap
Old Apr 13, 2009 | 06:40 PM
Turbo civic 704's Avatar
New User
Default N/A spark plug gap
wats the best for an all motor its a gsr type r pistons b16 head ls crank wat should i gap at
Old Apr 13, 2009 | 07:14 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: N/A spark plug gap
whatever the dyno tells you to gap it at. If you don't have access or money for the dyno, use stock gap.
Old Apr 13, 2009 | 08:22 PM
slambedcivic's Avatar
how much power has been gained from playing with plug gap?
Old Apr 14, 2009 | 01:14 PM
00Red_SiR's Avatar
All Motor Mentor
not much, maybe 1 hp or so on most 4 cylinders but the general rule of thumb is that you want to go as large on the gap as your ignition system can support without blowing out the spark. Experimenting on the dyno with plug gaps usually shows up in the smoothness of the graph lines rather than large power gains.
Brandi18c1
Dec 13, 2012 09:21 PM
ek99si
Jan 23, 2009 04:48 PM
sylvain
Oct 8, 2004 07:57 AM
Casey
124
Jan 17, 2004 07:11 PM
trbob16a
Oct 5, 2003 09:21 PM
