power windows in crx
Old Apr 13, 2009 | 05:28 PM
crx_si-r's Avatar
Default power windows in crx
i was curious to see how easy/hard it is to put power windows in a crx. i know that they can be sourced from an ultra rare lhd crx in canada and over seas. but what i want to know is if anyone has been able to conver 4DR system into a crx. while looking online i also found this..
http://www.a1electric.com/Merchant2/...ct_Code=HD31-K
its said to be a specific kit for the "88-92 crx" as they posted it, has anyone ever tried it?
Old Apr 13, 2009 | 07:00 PM
Crx Jimmy's Avatar
Default Re: power windows in crx
thats a damn nice looking unit, you might be able to find some jdm switches and flip them upside down and use those motors/regulators.
Old Apr 13, 2009 | 07:47 PM
clovis88crx's Avatar
the edm crx's are LHD like from Germany. they are hard to find but do show up on ebay for around $600 for the power window setup with door panels
Old Apr 13, 2009 | 07:51 PM
crx_si-r's Avatar
yea i already posted that im not trying to go with LHD crx's that ultra rare from canada and overseas. im trying to see if there is any other type of alternative that can be used to get power windows in a crx.
Old Apr 13, 2009 | 07:57 PM
spens 91 Ef's Avatar
1988-1992 crxs lol i didnt think they made crxs in 92
Old Apr 13, 2009 | 07:59 PM
crx_si-r's Avatar
i believe there was a 92 crx in japan
Old Apr 13, 2009 | 08:05 PM
i did not know that i thought i was right with they stopped making them in 91
Old Apr 13, 2009 | 09:25 PM
n3h3bkau's Avatar
I ended up doing it with the 4dr regulators, have I had to do it all over again I would probably gone with the A1 kit. 2 reasons...
1. Unknown usage of the power window regulators off a used car (driver more used and is more worn out in most cases)
2. Depending on how you swap it out the "gear" on the 4dr has more travel, so if you don't swap just the motor and keep the rest of the regulator you end up with a window that likes to bottom out on the door. (Not so good, live and learn) *oops
As for switches, grab some rear Legend switches and get yourself a EK armrest. The switches fit perfectly into those 4 little pop outs and it makes less wiring for you because both the driver and passenger can reach them and without cutting new holes into you door cards.
Old Apr 14, 2009 | 12:28 AM
kojack_0's Avatar
crx ended in 91. honda manufacturers did not finish distributing them until early 92. and thus people registered them early 92.
Old Apr 14, 2009 | 12:40 AM
foxjaeger's Avatar
lol, i love how you guys are arguing about when they stopped making the CRX.
too funny.
Old Apr 14, 2009 | 05:35 PM
i wouldnt call it arguing i thought i was right with 91 and someboday proved me wrong and thats cool i learned something new
Old Apr 22, 2009 | 05:41 AM
crx_si-r's Avatar
is it possible to swap out the right side window motor onto the left side motor?
Old Apr 22, 2009 | 05:49 AM
~sp33~'s Avatar
EFB055
Perhaps if you could swap just the motor itself, if the motor isn't able to be detached from the swing arm mechanism then probably not.
I can't remember if you could detach them or not though.
Old Apr 22, 2009 | 07:10 AM
crx_si-r's Avatar
So I have a set jdm power windows, I guess what I. Going to have to do is flip the driver side switches upside down.
Old Apr 22, 2009 | 08:30 AM
vw eater's Avatar
thats what i would do
Old Apr 22, 2009 | 09:50 AM
jlicrx's Avatar
http://www.cardomain.com/MakeModel/H...l/all/all/1992
Old Apr 22, 2009 | 11:07 AM
crx_si-r's Avatar
I was able to make the right side work out, I took out the switch and easily flipped it over, I'm going to get home later and sketch out how I'm going to make a plug n play harness. I'll keep everyone posted
Old Apr 22, 2009 | 06:42 PM
~sp33~'s Avatar
EFB055
Good stuff.
Old Apr 22, 2009 | 07:25 PM
crx_si-r's Avatar
ok i have already figured out the wiring for the power windows here is my question...
can i have both my power folding mirrors and my power windows running off the same accessory slot on my fuse box?
given i dont really mess with my mirrors unless its to fold them in as im the only person who drives my car, and both options in my car only use current when i push their button. or will i be blowing some fuses? thanks for all the help guys..i will upload some pics of my power window set up shortly.
Old Apr 22, 2009 | 07:30 PM
crx_si-r's Avatar
pics of set up....
please ignore the GF's yorkie in the pics
Old Apr 22, 2009 | 08:51 PM
crx_si-r's Avatar
after thinking about it, i tried it and it bolted up perfectly, i thought about swapping out the motors to the opposite side. ie passenger in drivers spot and vice versa. has anyone ever tried it this way? the only difference i see by doing it this way is that the motor is upside down but i dont think this will affect much because the motor is still going to be turning its gear.
Old Apr 23, 2009 | 06:32 PM
crx_si-r's Avatar
now here another question:
since i swapped out the motors and they are now upside down, will i have to re-pin the wiring so that when i push the button down on the driver side it wont roll up instead?
Old Apr 23, 2009 | 06:35 PM
~sp33~'s Avatar
EFB055
Didn't you flip the switches?
Old Apr 23, 2009 | 06:46 PM
crx_si-r's Avatar
yes but if i had only flipped the switches then i wouldnt have the auto up/down feature on the driver side, it would be on the passenger side. thats why i decided to swap the motors as well. by doing this they face down instead of up which i dont think will affect anything.
Old Apr 28, 2009 | 05:34 AM
crx_si-r's Avatar
ok so here is what i did. i swapped the switches and motors. so now everything works like its supposed to. when i push down on the switches windows roll down. i will take a small video when i get home. thanks everyone.
